Forces in compressible internal flow
Hi all,
I tried calculate forces that act on cylinder inside a pipe. when i used simplefoam ,i get very good result. but when i switch to rhoporoussimplefoam (with zero porosity - i use it as a template for steady state compressible flow - air) i get wrong direction and component of force greater x150 . for finding force i used : functions ( forces { type forces; functionObjectLibs ("libforces.so"); //Lib to load patches (buhna); // change to your patch name rhoInf 1.24; //Reference density for fluid CofR (0 0 0); //Origin for moment calculations } ); Is there anyone who can explain how do it right. thanks in advance Sasha |
hi all,
anyone have expirience with force Utility for use it for Compressible Flow Fields ? i tried look at forum but:( nothing. please help, becouse i have very strange result ,and i don't understand where is problem thank you p.s. i tried also with rhoSimpleFoam, and with rhoTurbFoam and i get similar result as in rhoporoussimplefoam.I work in O.F. 1.5 and geometry from SALOME. If there some indication that problem in mesh? i read that yplus in turbulent flow must be 30<y+<100, in my case average of y+ on cylinder is 1 (flow is turbulent, RE>20000). wait for your suggestion . thank in advance Sasha |
i tried refine the mesh - the same result.
what i should to do:confused: |
I' sorry,
But I never need to calculate forces. What is the turbulence model that you are using? Do you use wall functions? Because if you do the y+ around 30 and 100 should work fine, but if you don't use wall functions you need a low-Re turbulence model that can solve the boundary layer. Hope it helps, CX |
Hi Carlos,
thank you for your answer, i use k-e model, and not used wall function:confused: 1.where i can specify them? and what the rule? 2.which low-Re model you can suggest, and what's Re limitation for this model. 3.i read that y+ must be between 30 and 100 for fully turbulent flow- is right? 4.if your suggestion valid both for compressible and incompressible flow ? thank you very much Sasha. |
I never used a turbulence model in Foam, my experience is with FLUENT.
>>1.where i can specify them? and what the rule? All high-Re RANS turbulence models include wall-functions because it is inappropriate to use them without. The rule is that for use wall functions you need a valid y+ between 30 and 100 (300 in Fluent). >>2.which low-Re model you can suggest, and what's Re limitation for this model. If you want to use a low-Re you need a y+<=1. I could suggest Spalart-Allmaras, k-w or k-w SST. >>3.i read that y+ must be between 30 and 100 for fully turbulent flow- is right? Yes I think you are right, but If you want such y+ you need to coarse your mesh, in FLUENT is mandatory to use wall functions I think that in foam is also a need. |
hi,
>>All high-Re RANS turbulence models include wall-functions because it is inappropriate to use them without. i found them in RASproperties file :) i will try another RAS model,maybe it will help thank you for your help. sasha |
