-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Problem with internalField (http://www.cfd-online.com/Forums/openfoam/75402-problem-internalfield.html)
mecbe2002 April 24, 2010 04:40
3 Attachment(s)
Hi all,
I am simulating flow over missile.
The freestream Mach no is 0.6, angle of attack is zero & solver is "rhoSimpleFoam"
dimensions [0 1 -1 0 0 0 0];
internalField uniform (205.9392 0 0);
boundaryField
bt // "bt" is the missile body&tail
type slip;
outlet
type zeroGradient;
inlet
type fixedValue;
value uniform (205.9392 0 0);
defaultFaces
type empty;
At the tail fin face, the velocity magnitude(resultant) is zero at time=0. Why?
After the simulation also i get around 0.16m/s at the tail fin fact, but this is not correct. This may be because of the velocity field around fin face at time =0. Plz look at the snapshots.
Regards
Gopi
truong_nm April 24, 2010 10:57
Would you mind attaching the whole case files please ?
We don't see the mesh on your screenshots. For the moment, I am quite sure that your boundary conditions are missing something. However, your velocity BCs seem good.
Regards
Minh
