Home > Forums > OpenFOAM
Force Force-coeffs 3D simulation
Old   April 25, 2010, 12:45
Default Force Force-coeffs 3D simulation
Herman
enry is on a distinguished road
Hi all,
I'm doing a 3D simulation on Vertical Axis Wind Turbine. I need to calculate the force on surface. I attached the following lines to my controlDict file.
force
type forces;
functionObjectLibs ("libforces.so"); //Lib to load
patches (blades); // change to your patch name
rhoName rhoInf;
rhoInf 1.225; //Reference density for fluid
CofR (0 0 0); //Origin for moment calculations
outputControl timeStep;
outputInterval 1;
forceCoeffs
// rhoInf - reference density
// CofR - Centre of rotation
// dragDir - Direction of drag coefficient
// liftDir - Direction of lift coefficient
// pitchAxis - Pitching moment axis
// magUinf - free stream velocity magnitude
// lRef - reference length
// Aref - reference area
type forceCoeffs;
patches (blades);
rhoName rhoInf;
rhoInf 1.225;
CofR (0 0 1);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (1 0 0);
magUInf 6;
lRef 1;
Aref 1;
outputInterval 1;
If the model is 2D no errors appear on the screen, but when I run a 3D simulation appear the following error:
*** glibc detected *** turbDyMFoam: corrupted double-linked list: 0x088466f8 ***
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6[0xb593b0cd]
/lib/tls/i686/cmov/libc.so.6[0xb593c88e]
/lib/tls/i686/cmov/libc.so.6(cfree+0x90)[0xb59404f0]
/home/enrico/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/lib/libstdc++.so.6(_ZdlPv+0x21)[0xb5b1d051]
/home/enrico/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/lib/libstdc++.so.6(_ZNSs4_Rep10_M_destroyERKSaIcE+0x1d )[0xb5afb61d]
/home/enrico/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZN4Foam14primitiveEntryD0Ev+0x111)[0xb5d0a531]
/home/enrico/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZN4Foam10dictionaryD2Ev+0x79)[0xb5d03d79]
/home/enrico/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZN4Foam15dictionaryEntryD0Ev+0x33)[0xb5d10da3]
/home/enrico/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so(_ZN4Foam10dictionaryD1Ev+0x79)[0xb5d023a9]
/home/enrico/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so[0xb5c8eaeb]
/lib/tls/i686/cmov/libc.so.6(__cxa_finalize+0xb1)[0xb58ff3b1]
/home/enrico/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so[0xb5c8e893]
/home/enrico/OpenFOAM/OpenFOAM-1.5-dev/lib/linuxGccDPOpt/libOpenFOAM.so[0xb5f9531c]
/lib/ld-linux.so.2[0xb771a00f]
/lib/tls/i686/cmov/libc.so.6(exit+0xd4)[0xb58ff084]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe8)[0xb58e7458]
turbDyMFoam(_ZNK4Foam11regIOobject11writeObjectENS _8IOstream12streamFormatENS1_13versionNumberENS1_1 5compressionTypeE+0xcd)[0x8058ee1]
======= Memory map: ========
[..] etc etc etc etc etc etc etc etc etc etc etc etc etc etc etc etc etc etc etc etc
Can anybody help me?
Thanks in advance.
Enry.
enry is offline   Reply With Quote
Old   July 14, 2011, 09:41
Default 3d VAWT
s.rasoul_varedi
desert_1250 is an unknown quantity at this point
Send a message via Yahoo to desert_1250
Hi herman, i hope that you are well
i have some question a bout 3d VAWT. i can simulate 2d VAWT with 3 bldes with GGI interface successfully; and now i wanna simulate 3 dimentional of it. would you guide me how perform it? would you send me any documention a bout 3d simulation. my experience a bout 3d dimention in OpenFOAMis very low.
tanx
__________
Rasoul
desert_1250 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Quadrotor helicopter propeller simulation Attesz CFX 12 August 31, 2012 04:06
decreaing pressure force in 2phase model michaelzhang FLUENT 0 February 26, 2010 09:27
DEFINE_CG_MOTION and pressure force Teo Fumagalli FLUENT 0 April 11, 2008 10:25
CFX-solver force monitor Maga CFX 0 February 26, 2008 20:31
Too high pressure force ? Tim Franke Main CFD Forum 1 March 15, 2000 00:36
