How do I fix the temperature within a flow?
Old   April 26, 2010, 05:36
Question How do I fix the temperature within a flow?
Carlos Trejo
CarlosT is on a distinguished road
Greetings FOAMers!
I am a fairly new openfoam user, working on Vortex Breakdown in a combustion chamber. My aim is to try to simulate a flame front, by creating a (cone-shaped) surface in which I fix the temperature.
The problem is, I think some kind of energy source term may be needed, for otherwise it just sucks out the heat out of the fluid next to the "flame front", leading to negative temperatures...
Do you have any idea on how to add this "energy source term" or any alternative solution?
Thanks a lot,
Carlos
CarlosT is offline   Reply With Quote
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
hypersonic flow temperature Tamjid FLUENT 2 August 21, 2008 01:36
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
If I fix the Temperature ... x. ye CFX 0 May 24, 2000 15:58
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
