-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Tutorial Hemida for OF-1.6 (http://www.cfd-online.com/Forums/openfoam/75524-tutorial-hemida-1-6-a.html)
flowris April 28, 2010 04:16
I am currently trying the InterFoam tutorial, written by Hassan Hemida, which can be found at http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2007/. I think this tutorial has been written for an older version of interFoam. The laminar case was easily runned, but for the RAS case, I needed to change quite a lot of the files. The files I downloaded were written for reasInterFoam, while in OpenFOAM-1.6, RAS simulation is integrated in the normal interFoam solver.
The case I set up was more or less a mixture between the original files from Mr. Hemida and the RAS damBreak tutorial.
When running the case, I received time step continuity errors in the first time step. My log file looks like this:
Create time
Create mesh for time = 0
Reading g
Reading field p
Reading field alpha1
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
sigmaEps 1.3;
time step continuity errors : sum local = 9.77995e-06, global = -9.77995e-06, cumulative = -9.77995e-06
DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 7.62511e-09, No Iterations 178
DICPCG: Solving for pcorr, Initial residual = 4.89025e-10, Final residual = 4.89025e-10, No Iterations 0
time step continuity errors : sum local = 7.45727e-14, global = -9.41208e-16, cumulative = -9.77995e-06
Courant Number mean: 0.000122101 max: 0.0277845
Starting time loop
Courant Number mean: 0.000878914 max: 0.2
deltaT = 0.000719825
Time = 0.000719825
MULES: Solving for alpha1
Liquid phase volume fraction = 0.0220225 Min(alpha1) = 0 Max(alpha1) = 1
Liquid phase volume fraction = 0.0220401 Min(alpha1) = 0 Max(alpha1) = 1
Liquid phase volume fraction = 0.0220577 Min(alpha1) = 0 Max(alpha1) = 1
Liquid phase volume fraction = 0.0220753 Min(alpha1) = 0 Max(alpha1) = 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00876324, No Iterations 94
DICPCG: Solving for p, Initial residual = 3.10228e-06, Final residual = 2.79213e-08, No Iterations 40
DICPCG: Solving for p, Initial residual = 0.000594512, Final residual = 5.7006e-06, No Iterations 92
DICPCG: Solving for p, Initial residual = 3.78488e-05, Final residual = 3.60187e-07, No Iterations 42
DICPCG: Solving for p, Initial residual = 0.00218362, Final residual = 1.99928e-05, No Iterations 86
DICPCG: Solving for p, Initial residual = 3.32376e-05, Final residual = 3.11412e-07, No Iterations 37
DICPCG: Solving for p, Initial residual = 0.00169515, Final residual = 1.46306e-05, No Iterations 82
DICPCG: Solving for p, Initial residual = 1.52903e-05, Final residual = 9.49297e-08, No Iterations 84
time step continuity errors : sum local = 2.1649e-09, global = 9.53018e-12, cumulative = -9.77994e-06
Can anyone help? (I am am not sure that I really understand what a time step continuity error means)
johnb April 28, 2010 07:07
You will always see "time step continuity errors" during your simulations, ideally it should be zero. So as long as it it is small and not increasing during simulation everything is fine.
If it explodes you have either specified incorrect BC or your mesh quality might be poor.
Regards,
John
flowris April 29, 2010 03:41
complete log file
Thank you. I didn't give the complete log file, but it shows some more errors:
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-f802ff2d6c5a
Exec : interFoam
Date : Apr 29 2010
Time : 09:32:01
Host : rmawsynab105478
PID : 3037
Case : /home/jmatthei/OpenFOAM/jmatthei-1.6/run/tutorials_chalmers/turbFillBottleKEps_1
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Reading g
Reading field p
Reading field U
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
sigmaEps 1.3;
Starting time loop
Time = 0.000719825
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00877667, No Iterations 94
DICPCG: Solving for p, Initial residual = 3.10704e-06, Final residual = 2.79188e-08, No Iterations 40
DICPCG: Solving for p, Initial residual = 0.000594512, Final residual = 5.62055e-06, No Iterations 92
DICPCG: Solving for p, Initial residual = 3.73173e-05, Final residual = 3.68162e-07, No Iterations 42
DICPCG: Solving for p, Initial residual = 0.00218363, Final residual = 1.99515e-05, No Iterations 86
DICPCG: Solving for p, Initial residual = 3.3169e-05, Final residual = 3.11278e-07, No Iterations 37
DICPCG: Solving for p, Initial residual = 0.00169515, Final residual = 1.46307e-05, No Iterations 82
DICPCG: Solving for p, Initial residual = 1.52904e-05, Final residual = 9.53714e-08, No Iterations 84
time step continuity errors : sum local = 2.17497e-09, global = 9.60109e-12, cumulative = -9.77994e-06
#0 Foam::error::printStack(Foam::Ostream&) in "/home/jmatthei/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/jmatthei/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/jmatthei/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/jmatthei/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleTransportModels.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/jmatthei/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/jmatthei/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libincompressibleRASModels.so"
#7 main in "/home/jmatthei/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interFoam"
#8 __libc_start_main in "/lib/libc.so.6"
#9 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
su_junwei April 29, 2010 04:49
Hi
It seems that you have set a zero value for k or epsilon on a certain boundary. Please try using a very small value instead.
Junwei
flowris May 3, 2010 05:19
small values for k and epsilon -> ok
Thanks Junwei,
I had values of 0.1 for k and epsilon in the internal field of timestep 0, but values zero on some of the boundaries. When I changed to values of 0.1 everywhere in timestep zero, my tutorial ran fine.
rlobosco May 28, 2010 13:21
2 Attachment(s)
I followed step by step of interFoam tutorial by Hassan Hemida. And applied exactly the same conditions to the geometry of a stepped spillway. But unreal oscillations appear at the interface, even more when I increase the length of the dam, as showed in the second picture attached. I realised that oscilations start from upper right coordenate of the box for defining alpha equal 1.
Can anyone give me a hint how to avoid this interface problem?
Someone tested this dambreak problem in 3D with geometry topology changes? The flow is also going from down the crest, it would stop to flow earlier.
Thanks for help.
With best regard,
flowris May 11, 2012 10:17
Oscillations on the air-water interface are a common problem using interFoam. Mesh refinement and good fvSchemes are the key to improve. Find more info here:
http://www.cfd-online.com/Forums/ope...ship-flow.html
vishal_s August 21, 2013 00:11
Hey flowris, I am also trying to simulate the InterFoam tutorial, written by Hassan Hemida, I have used the boundary conditions given below but unable to reproduce the same result as given in the tutorial for the laminar case (doing laminar case first). May you kindly look at the initial boundary conditions and let me know whether it is fine or not.
For U:
| \\ / O peration | Version: 2.1.1 |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (0 -0.1 0);
inletWall
type fixedValue;
value uniform (0 0 0);
bottleWall
type fixedValue;
atmosphere
type inletOutlet;
inletValue uniform (0 0 0);
frontAndBack
type empty;
For P_rgh
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
inletWall
type zeroGradient;
bottleWall
type zeroGradient;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
frontAndBack
type empty;
For alpha1
FoamFile
version 2.0;
format ascii;
location "0";
object alpha1;
dimensions [0 0 0 0 0 0 0];
boundaryField
inlet
type fixedValue;
value uniform 1;
inletWall
type zeroGradient;
bottleWall
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
frontAndBack
type empty;
flowris August 21, 2013 02:35
In comparison to the original case of Hamida, there are no differences in 0/U.
However, 0/pd and 0/gamma.org are:
|  \\    /  O peration    | Version:  1.4.1                                |
|  \\  /    A nd          | Web:      http://www.openfoam.org              |
// Field Dictionary
FoamFile
    version        2.0;
    format          ascii;
    root            "/home/hassan/OpenFOAM/hassan-1.4.1/run/interFoam";
    case            "fillBottle";
    instance        "0";
    local          "";
    object          pd;
boundaryField
    inlet
        type            zeroGradient;
    inletWall
        type            zeroGradient;
    bottleWall
        type            zeroGradient;
    atmosphere
        type            fixedValue;
        value          uniform 0;
    frontAndBack
        type            empty;
|  \\    /  O peration    | Version:  1.4                                  |
FoamFile
    version        2.0;
    format          ascii;
    root            "";
    case            "";
    instance        "";
    local          "";
    object          gamma;
boundaryField
    inlet
        type            zeroGradient;
    inletWall
        type            zeroGradient;
    bottleWall
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        value          uniform 0;
    defaultFaces
        type            empty;
you can still download the files here: http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2007/
vishal_s August 21, 2013 06:19
flowris, thanks for the prompt reply.But why in the initial dynamic pressure field , the boundary condition for the atmosphere field is kept "fixed zero".Don't you think as the as the water
starts entering the atmosphere, the dynamics pressure is going to have some finite value??
flowris August 21, 2013 06:33
That is totally reasonable. If I remember well, the tutorial case ends before the bottle is completely filled. All I did was giving you the BCs of the original tutorial, I am not saying they are the most physically correct ones. Did you try it with these?
vishal_s August 26, 2013 15:07
Flowris,I tried both BCs and it doesn't makes much difference. I would be really grateful, if you may kindly look at the initial boundary conditions for turbulence, I am trying for last few days but unable to get the proper result.May you kindly tell what is the mistake.
File for epsilon :
FoamFile
version 2.0;
format ascii;
location "0";
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 0.1;
boundaryField
inlet
type fixedValue;
value uniform 0.1;
inletWall
type epsilonWallFunction;
value uniform 0.1;
bottleWall
value uniform 0.1;
atmosphere
type inletOutlet;
inletValue uniform 0.1;
value uniform 0.1;
frontAndBack
type empty;
FIle for k :
FoamFile
version 2.0;
format ascii;
location "0";
object k;
dimensions [0 2 -2 0 0 0 0];
boundaryField
inlet
type fixedValue;
value uniform 0.1;
inletWall
type kqRWallFunction;
value uniform 0.1;
bottleWall
value uniform 0.1;
atmosphere
type inletOutlet;
value uniform 0.1;
frontAndBack
type empty;
FIle for nut :
FoamFile
version 2.0;
format ascii;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
boundaryField
inlet
type fixedValue;
value uniform 0.1;
inletWall
type nutkWallFunction;
value uniform 0.1;
bottleWall
value uniform 0.1;
atmosphere
type calculated;
value uniform 0;
defaultFaces
type empty;
File for nuTilda:
FoamFile
version 2.0;
format ascii;
object nuTilda;
boundaryField
inlet
type fixedValue;
value uniform 0;
inletWall
type fixedValue;
value uniform 0;
bottleWall
type fixedValue;
value uniform 0;
atmosphere
type inletOutlet;
value uniform 0;
frontAndBack
type empty;
