conjugateHeatFoam:given field does not correspond to patch
Hi everybody,
I was trying to simulate a CHT problem, a 2d cylinder in cross-flow, by means of conjugateHeatFoam. I think everything it's ok in the settings and in particular: ------------------- SOLID SIDE-------------------- interface { type regionCouple; nFaces 80; startFace 1150; shadowRegion region0; shadowPatch sphere; attached on; } -------------------FLUID SIDE------------------- sphere { type regionCouple; nFaces 80; startFace 15920; shadowRegion solid; shadowPatch interface; attached on; } this should be ok since the interface patch is correctly defined on both side in the boundary files. However I get the following error message when I try to run it: given field does not correspond to patch. Patch size: 80 field size: 0 From function PatchToPatchInterpolation::faceInterpolate(const Field<Type> ff) in file /home/nettis/OpenFOAM/OpenFOAM-1.5-dev/src/OpenFOAM/lnInclude/PatchToPatchInterpolate.C at line 133. FOAM aborting Any idea about that?? thanks in advance, Dino |
ok,
I found the problem, the remoteField in the BCs was declared as DT in the T file!! Have a nice weekend. |
