Bash complete bindings
Like Tree1Likes
  • 1 Post By josp
Old   May 3, 2010, 09:00
Default Bash complete bindings
Johan Spång
josp is on a distinguished road
Hi, I created a simple python script (40 lines..) for generating bash complete bindings for application arguments. Example:
~/OpenFOAM/OpenFOAM-1.6.x/applications/bin> foamToVTK - [TAB]
-allPatches -case -constant -excludePatches -fields -latestTime -noFaceZones -noLinks -noZero -pointSet -srcDoc -time
-ascii -cellSet -doc -faceSet -help -nearCellValue -noInternal -noPointValues -parallel -region -surfaceFields -useTimeName
To get foamToVTK -latestTime, only foamToVTK -l [TAB] has to be typed in.
The bindings are really basic and only concerns arguments starting with a ' - '
#basic script for generating bash complete bindings.
import os, subprocess
rootdirs=['/home/josp/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/',
'/home/josp/OpenFOAM/josp-1.6.x/applications/bin/linux64GccDPOpt']
outFile='./complete_OpenFOAM'
def createFunction(file, arguments):
    return '_OpenFOAMcomplete'+file+'()\n{\n    local cur prev opts\n    COMPREPLY=()\n    cur="${COMP_WORDS[COMP_CWORD]}"\n    \
prev="${COMP_WORDS[COMP_CWORD-1]}"\n    opts="' + arguments+'"\n    if [[ ${cur} == -* ]] ; then\n        COMPREPLY\
=( $(compgen -W "${opts}" -- ${cur}) )\n        return 0\n    fi\n\
    if [[ ${prev} == * ]] ; then\n        COMPREPLY=( $(compgen -f ${cur}) )\n        return 0\n    fi\n}\n'
text = []
execs = []
all=[]
# Grab executable output on -help argument
for rootdir in rootdirs:
    for subdir, dirs, files in os.walk(rootdir):
        for file in files:
            print file
            p =subprocess.Popen([file, '-help'], stdout = subprocess.PIPE)
            if p.wait() == 0: # Check that the executable makes a clean exit, otherwise skip
                execs.append(file)
                text.append(p.communicate()[0].strip('\n'))
# Parse options, really messy. It's probably better to use an xml parser but this works for now..
for i in execs:
    parsed = text[execs.index(i)].split(i)[-1].split('>')[-1].lstrip(' ').replace('  ', ' ').split('] ')
    result = ''
    for k in parsed:
        j = k.split(' ')[0]
        for q in j:
            result += q.lstrip('[').rstrip(']').strip(' ')
    all.append([i, result.replace('-', ' -').lstrip(' '), len(result)])
# Write the bindings to specified outFile
f = open(outFile, 'w')
for i in all:
    f.write(createFunction(str(all.index(i)), i[1])+"complete -F _OpenFOAMcomplete"+str(all.index(i)) + " " + i[0] + "\n\n")
f.close()
Remember to source (i.e. type ".complete_OpenFOAM") the bindings.
Feel free to modify and improve.
wyldckat likes this.
Last edited by josp; May 3, 2010 at 10:00. Reason: The script was blocking file completion
josp is offline   Reply With Quote
Old   May 4, 2010, 04:02
akidess's Avatar
Anton Kidess
Great, thanks for sharing! Instead of having to manually specify the rootdirs, you can use the environment variables $FOAM_APPBIN and $FOAM_USER_APPBIN.
mesh a complete plane horsee FLUENT 13 April 17, 2010 20:20
how to view the complete results shokry FLOW-3D 5 February 3, 2009 13:56
FLOW OVER COMPLETE AIRCRAFT MATT Phoenics 11 November 1, 2005 11:07
Ask for complete theory of T-omega formulation! Hongtao Wang Main CFD Forum 0 May 11, 2005 21:26
Star-HPC, Bash Wak Siemens 1 June 2, 2004 15:44
