addPatchCellLayer
I would like to add a cell layer on a wall patch of a pipe to be able to calculate the gradient over the original patch faces. To add a cell layer it seems that the addPatchCellLayer class should be able to do it for me, but I don't understand how to obtain the arguments for the setRefinement function? Thanks /NW |
Copy and paste from autoLayerDriver.C did it.
/NW |
Niklas,
Did you add a cell-layer towards the interior of the domain (fluid)? Or was it an addition outside the mesh? Could you post your code, if that's possible... It would be really helpful. Thanks |
I just added a cell layer as an addition to the mesh to be able to compute derivatives of a field on the "old" boundaries. Adding the code below but as I wrote it's just a copy and paste from the doxygen manual. All the Best /NW int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createTime.H" # include "createMesh.H" ////////////////////////////////////////////// // AddCellLayer ////////////////////////////////////////////// addPatchCellLayer addLayer(mesh); label nLayers=1; polyTopoChange meshMod(mesh); const polyBoundaryMesh& patches = mesh.boundaryMesh(); // Count faces. label nFaces = 0; nFaces = patches[0].size(); // Collect faces. labelList addressing(nFaces); nFaces = 0; const polyPatch& pp = patches[0]; label meshFaceI = pp.start(); forAll(pp, i) { addressing[nFaces++] = meshFaceI++; } indirectPrimitivePatch ipp(IndirectList<face>(mesh.faces(), addressing),mesh.points()); // scalar thickness = 1e-4; scalar thickness = 3e-4; vectorField faceNormals = pp.faceNormals(); pointField patchDispl(pp.nPoints(), vector::zero); pointField pointNormals(pp.pointNormals()); // Determine pointNormal // Start off from same thickness everywhere (except where no extrusion) patchDispl = thickness*pointNormals; // Add topo regardless of whether extrudeStatus is extruderemove. // Not add layer if patchDisp is zero. addLayer.setRefinement(nLayers,ipp,patchDispl,mesh Mod); // With the stored topo changes we create a new mesh so we can // undo if neccesary. autoPtr<fvMesh> meshPtr; autoPtr<mapPolyMesh> map = meshMod.makeMesh ( meshPtr, IOobject ( mesh.name(), static_cast<polyMesh&>(mesh).instance(), mesh.thisDb(), static_cast<polyMesh&>(mesh).readOpt(), static_cast<polyMesh&>(mesh).writeOpt() ), // io params from original mesh but new name mesh, // original mesh true // parallel sync ); // Update numbering on addLayer: // - cell/point labels to be newMesh. // - patchFaces to remain in oldMesh order. addLayer.updateMesh ( map, identity(pp.size()), identity(pp.nPoints()) ); mesh.write(); runTime.write(); Info<< "END" << endl; return(0); } |
Thanks a ton for the code, Niklas.
Just in case someone's looking for a simple solution, here's the alternative: 0. Backup the original mesh. 1. Call extrudeMesh using the following settings for extrudeProperties: Code:
3. Use mergeMeshes with the original and new cases. 4. Use stitchMesh with the -perfect flag. |
