May 4, 2010, 16:33 |
Cells And Points
Andreas Beck
Rep Power: 16 |
Hi everyone,
I have some questions to the polymesh in OpenFoam 1.6. For my further computations I need the pressureloads on the several wall elements, without using a postprocessor. So I tried to find the pressures in the P file. There, they are all listet, but I am not able to identify the correct cell id. My problem here is that I dont know which cell id corresponds to which wall id. I tried to get these via the points and the cells file in the polymesh, but in version 1.6 no cell file is created. So my questions are: Where is the information to the relation between points and cells stored and how can I get access to it ? Is it possible to say OpenFoam that a cell file should be created? Is it possible to transform the pressure to nodalforces on the wallpoints and can this then be written out ? Is it possible to define a kind of outputset, for which the pressures are written out? I hope that somebody can help me with all these questions. So,thanks a lot Andy |
May 4, 2010, 19:33 |
Alan Russell
Rep Power: 16 |
Andy, I don't have access to Foam from here to check the details, but the boundary file in the polymesh directory should help you figure out what point/cell range applies to each of your patches. There is a post processing utility called sample that will help you access data. It has a dictionary file with a lot of settings - I haven't spent much time exploring it yet, but I was able to pull out a set of velocity points. You can search the forum on sample for more info. Good luck,
Alan |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[Commercial meshers] Converting a mesh with splitted cells using fluentMeshToFoam | jlpelerin | OpenFOAM Meshing & Mesh Conversion | 4 | April 25, 2011 16:56 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Mesh to points cells faces and boundaries files | billy | OpenFOAM Pre-Processing | 19 | April 18, 2006 15:38 |
