December 29, 2010, 08:33 |
k-omega in wingmotion tutorial
Jonas Lintermans
Dear CFD-community,
I would like to understand the following piece of code in the wingMotion-tutorial with pimpleDyMFoam-solver. In the 0/omega-file it states: Code:
wing { type omegaWallFunction; Cmu 0.09; kappa 0.41; E 9.8; beta1 0.075; value uniform 32; } Also, I'm trying to run the tutorial longer than 1 sec, now 3sec but OpenFOAM stops calculating after 2.79sec, finishing with an error: sigFpe and Foam::error:rintStack(Foam::Ostream&). Changing the tolerances a little bit in the fvSolution-file resulted in a extension of the calculation to 2.93sec. Any idea how to solve the case for 5sec without giving an error? Greetings, |
December 29, 2010, 16:34 |
Dave
Rep Power: 15 |
Jonas,
Those with the exception of "values= 32", the values listed are intrinsic either to the turbulence model itself or to turbulence theory (kappa = 0.41). If you change these values you will likely get something unphysical. Also if you neglect to have those lines, OF will default to the default values for them (which off the top of my head those are the values). The "values= 32" refers to the value of omega based on your given flow condition and this is the only value you are likely to want to change if you are changing things like velocity, viscosity, etc. Hope that helps. Dave |
k-omega, printstack, sigfpe, tutorial, wingmotion |
Display Modes | |
Tutorial for subcooled nucleate boiling | Asghari | FLUENT | 42 | December 10, 2018 12:42 |
[snappyHexMesh] wingMotion Tutorial | dancfd | OpenFOAM Meshing & Mesh Conversion | 3 | November 13, 2016 11:12 |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 06:34 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 04:25 |
Use of k omega turbulence model | john_w | OpenFOAM Running, Solving & CFD | 2 | September 22, 2009 06:15 |
