k-epsilon, Stagnation point, high Re, steady state. |
May 19, 2017, 21:25 |
Anders Utnes
Rep Power: 8 |
Hi
Is there any standard solver I can use for this case: I have a steady state geometry with a stagnation point, and high reynolds number (10^5). I need to accurately predict the dragcoefficient for the geometry. I was planing to test k-epsilon in simpleFoam, but I dont know how to avoid the stagnation point anamoly. |
May 20, 2017, 02:38 |
Uwe Pilz
Rep Power: 15 |
Prediction pressures at higher Re is not an easy task. I recommend to start with a geometry where experimental data are available. Often the flow past a cylinder is used, for which the drag an lift coefficients are known.
If you have a decent mesh, RANS simulation usual give quite accurate results, even in 2D. You have to check whether the results stay nearly constant when you make the mesh finer. If you need taking into account more turbulence effects and have to switch to LES, you need a 3D mesh or at least a 2,5D mesh (a 2D mesh expanded to some degree in the third dimension).
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Display Modes | |
unsteady state to steady state | neetu kumari | OpenFOAM | 4 | June 14, 2016 19:16 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 14:32 |
Solver Suggestions: Incompressible, high pressure, 3 phases, steady state | Sam_CFD | OpenFOAM Running, Solving & CFD | 11 | March 9, 2015 06:40 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 15:37 |
