How to write a script to automatically modify the parameters of 0 / u file for simula |
July 18, 2020, 04:23 |
liwenpeng
Rep Power: 5 |
I need batch script to automate the process.
I may need to do several thousand simulations of flow around a rotating cylinder, the cylinder rotating speed from-100 to 100, the interval is 0.2. But at present, I adjust the parameters manually every time, and the post-processing is also carried out manually. Forthousands of simulations, it is impossible to realize. Is there anyway and how to automatically adjust parameters and simulate. ? I can not find any example about bash script,who could give me some example or tutorial about how to write the script. Do I need python or matlab or shell,I do not know,I am a new with poor programming skill. my openfoam run in Ubuntu Many thanks!! |
July 23, 2020, 17:45 |
Fumiya Nozaki
Rep Power: 18 |
You might want to take a look at the following tutorial: https://develop.openfoam.com/Develop...pleFoam/bump2D In this tutorial, RAS_MODEL in turbulenceProperties file is replaced to each turbulence model's name by Allrun sh script. Hope this helps, Fumiya
[Personal]
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
