May 17, 2010, 13:24 |
modifying XiFoam
Carlos Trejo
Rep Power: 16 |
Hi!
I´m having some trouble trying to modify the XiFoam solver. I´m trying to fix a flame in a combustion chamber. For this, I want to fix the value of the b field throughout the simulation. I´m not a great expert but I´d thought maybe including a new volScalarField, telling it to read and not to write would do the job: Info<< "Reading field b\n" << endl; volScalarField b ( IOobject ( "b", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ), mesh ); besides this, I took the following equation out of bEqn.H // Create b equation // ~~~~~~~~~~~~~~~~~ fvScalarMatrix bEqn ( fvm::ddt(rho, b) + mvConvection->fvmDiv(phi, b) + fvm::div(phiSt, b, "div(phiSt,b)") - fvm::Sp(fvc::div(phiSt), b) - fvm::laplacian(turbulence->alphaEff(), b) ); but it´s not working. I can compile the new solver with a failure warning "error: 'bEqn' was not declared in this scope createFields.H:31: warning: unused variable 'T'" but when I run the simulation with it, the b field does not remain stable. Does anyone have an idea what might be going wrong, or any hint in which direction to go? Thanks a lot |
May 17, 2010, 15:10 |
XiFoam breaks off
Carlos Trejo
Rep Power: 16 |
Hi again!
Actually I realised what I was doing was dumb, I´ve left everything as in the original solver except for the bEqn.H file, where I´ve changed the b equation: // Create b equation // ~~~~~~~~~~~~~~~~~ fvScalarMatrix bEqn ( fvm::ddt(rho, b) ); so that it will remain constant. I´ve run the case (with quite fine meshing) but it breaks off pretty soon... I suspect it´s aborting because of what I changed in the code (I got a floating point error), does anybody have any idea on how to solve this? Thank you a lot! |
May 17, 2010, 15:29 |
Carlos Trejo
Rep Power: 16 |
Hello!
I´ve tried aswell modifying the bEqn in this way: // Create b equation // ~~~~~~~~~~~~~~~~~ fvScalarMatrix bEqn ( fvm::ddt(b) ); it calculates for a little longer before breaking up. Anybody got a hint? Thank you very much |
May 18, 2010, 05:41 |
Carlos Trejo
Rep Power: 16 |
Anybody got a clue?
Thank you |
Display Modes | |
Modifying the laplacian operator | mlawson | OpenFOAM Running, Solving & CFD | 22 | July 16, 2018 05:56 |
XiFoam partially premix combustion | tavasoly | OpenFOAM Running, Solving & CFD | 0 | July 1, 2008 12:01 |
XiFOAM H2Air combustion | brgirgis | OpenFOAM Running, Solving & CFD | 0 | February 11, 2008 18:17 |
Modifying Turbulence Model Constants | Bean | FLUENT | 0 | February 12, 2006 19:33 |
XiFoam question | burningman | OpenFOAM Running, Solving & CFD | 0 | November 15, 2005 07:04 |
