Contact Angle
Old   May 22, 2010, 11:47
Default Contact Angle
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Dear FOAMers
Hi
I am working with interFOAM. I have two questions:
Is interFOAM considers contact angle between fluid and wall?
If not what is proper VOF based solver that consider contact angle?
Best regards
ata is offline   Reply With Quote
Old   May 23, 2010, 14:26
Eelco Gehring
feijooos is on a distinguished road
ata,
There are several different contact angle boundary conditions in OF that work with interFoam. Check the forum for explanations on how to set these up. You can find the different BC here: /src/transportModels/interfaceProperties/gammaContactAngle/
feijooos is offline   Reply With Quote
Old   May 24, 2010, 03:12
ata
ata's Avatar
ata kamyabi
Hi Eelco Gehring
Thank you very much for your reply
I have not OpenFOAM-dev and in interfaceProperties folder I have alphaContactAngle folder. Did you mean alphaContactAngle and constantAlphaContactAngle and dynamicAlphaContactAngle and timeVaryingAlphaContactAngle boundary conditions?
Best regards
Old   May 24, 2010, 11:59
Eelco Gehring
I think you mean that you are working with OF 1.6? It doesn't really matter, since the folders that you list are the BC's I was talking about. From those folders it is easily derived what to setup in your 0-directory.
Old   May 25, 2010, 00:57
ata
ata's Avatar
ata kamyabi
Hi
In dynamic contact angle there is four private data. "Equilibrium contact angle", "Limiting advancing contact angle", "Limiting receding contact angle" and "Dynamic contact angle velocity scale". Would you please tell me what is "Dynamic contact angle velocity scale" physically?
Thank you very much
Best regards
Old   May 25, 2010, 12:27
Eelco Gehring
take a look at this post: http://www.cfd-online.com/Forums/ope...act-angle.html
Old   May 26, 2010, 00:30
ata
ata's Avatar
ata kamyabi
Hi Eelco Gehring
Thank you very much for your reply.
Best regards
Dynamic contact angle rmousavibt Fluent UDF and Scheme Programming 12 October 31, 2021 22:38
contact angle yan FLUENT 4 November 6, 2012 04:22
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Theoretical background of formula for dynamic contact angle in interfoam sebastian_vogl OpenFOAM Running, Solving & CFD 3 June 22, 2009 12:25
About the Contact Angle Flora FLUENT 2 March 8, 2007 02:07
