Home > Forums > OpenFOAM
Problem with snappyHex: no body
Old   May 31, 2010, 16:22
Default Problem with snappyHex: no body
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Hi;
I'm moving my first steps with OF. I'm trying to mesh a simple circular cylinder. I get no error but when I run paraFoam the only thing I can get is the whole meshed domain without any body inside of it. The cylinder height is along the z axis, diameter is 60mm and height is 180mm. Here is my blockMeshDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (-0.5 -0.5 0)
    (0.5 -0.5 0)
    (0.5 0.5 0)
    (-0.5 0.5 0)
    (-0.5 -0.5 0.5)
    (0.5 -0.5 0.5)
    (0.5 0.5 0.5)
    (-0.5 0.5 0.5)
blocks
    hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1)
edges
patches
mergePatchPairs
and here's my snappyHexMeshDict:
FoamFile
    version         2.0;
    format          ascii;
    root            "/home/penfold/mattijs/foam/mattijs2.1/run/icoFoam";
    case            "cavity";
    instance        "system";
    local           "";
    class           dictionary;
    object          autoHexMeshDict;
castellatedMesh true;
snap            true;
addLayers       false;
geometry
    Cilindro.stl
        type triSurfaceMesh;
        name Cilindro;
castellatedMeshControls
    maxLocalCells 1000000;
    maxGlobalCells 2000000;
    minRefinementCells 0;
    nCellsBetweenLevels 1;
    features
    refinementSurfaces
        Cilindro
            level (4 5);
    resolveFeatureAngle 60;
    refinementRegions
    locationInMesh (0.3 0.3 0.3);
snapControls
    nSmoothPatch 3;
    tolerance 4.0;
    nSolveIter 30;
    nRelaxIter 5;
addLayersControls
    layers
    expansionRatio 1.0;
    finalLayerRatio 0.5;
    minThickness 0.25;
    nGrow 0;
    featureAngle 60;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 130;
    nBufferCellsNoExtrude 0;
meshQualityControls
{    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minFlatness 0.5;
    minVol 1e-13;
    minArea -1;
    minTwist 0.05;
    minDeterminant 0.001;
    minFaceWeight 0.05;
    minVolRatio 0.01;
    minTriangleTwist -1;
    nSmoothScale 4;
    errorReduction 0.75;
debug 0;
mergeTolerance 1E-6;
I know the domain is small and the mesh is coarse, this is just a tryout.
Thanx!
lovecraft22 is offline   Reply With Quote
Old   June 1, 2010, 01:08
Alan Russell
AlanR is on a distinguished road
lc22,
In blockMesh you only have one cell in the z direction. Your hex cells are 50 mm square and your cylinder is only 60 mm in diameter. Try blocks (0 1 2 3 4 5 6 7) (40 40 40) simpleGrading (1 1 1). This is still a coarse mesh, but it will be easier to see what's going on than with 20 blocks. Make sure the cylinder dimensions locate it within the box defined in your blockMesh. If the origin is 0,0,0 you should be OK. In snappy, try refinementSurfaces level (1 1) to start and experiment when you refine your mesh by using more blocks.
Alan
AlanR is offline   Reply With Quote
Old   June 1, 2010, 15:54
lore
Thank you Alan. Unfortunately that doesn't solve the problem: when I run paraFoam my cylinder is not there and the whole domain is meshed…
Old   June 2, 2010, 23:59
Alan Russell
Try opening the cylinder in ParaView to see the geometry the way OF will see it. You will also get to see where ParaView puts the origin. After you open the mesh, use the ParaView menu or file icon and browse to the file. If it looks OK, there's a surfaceCheck utility. I think the syntax is surfaceCheck Cilindro.stl. If the surfaceCheck thinks the surface is OK, and you're generating a hexagonal domain that's completely meshed with no cylinder in it, you probably are not locating the cylinder inside the mesh for some reason. You could try expanding the block (like from -2 to 2 in all dimensions) and see if the cylinder shows up. You could also try another .stl file. Maybe one of these things will help...
Alan
Old   June 7, 2010, 15:57
lore
You're probably right! There's something wrong with the dimensions of the cylinder.
Thank you!!
Old   June 23, 2010, 11:05
Default problem modelling surface with snappy
Silvia Di Francesco
gija79 is on a distinguished road
Hi everybody,
i'm trying to build a mesh with the snappyhexmesh utility.
I want to model the flow over a submerged island, but snappyhex seems to fail in snapping to island surface.
I want to use the InterFoam solver.
Maybe I did'nt prepare the dict file well, but the resulting mesh is very poor.
I prepared the background mesh with blockmesh.
This is my blockmesh file:
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(0 0 0)//0
(300 0 0)//1
(300 85 0)
(-170 85 0)//3
(-170 0 1)
(300 0 1)//5
(300 85 1)
(-170 85 1)//7
blocks
hex (0 1 2 3 4 5 6 7) (300 85 1) simpleGrading (1 1 1)
edges
patches
patch inlet
(0 4 7 3)
patch outlet
(1 5 6 2)
wall bottom
(0 4 5 1)
patch atmosphere
(3 7 6 2)
mergePatchPairs
This is the snappyhex dict file:
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
snap true;
addLayers true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
coral.stl
name coral;
refinementBox
type searchableBox;
min (60 20 -0.1);
max (98 27 1.1);
// Settings for the castellatedMesh generation.
// Refinement parameters
// While refining maximum number of cells per processor. This is basically
// the number of cells that fit on a processor. If you choose this too small
// it will do just more refinement iterations to obtain a similar mesh.
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 10;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 3;
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
// file "someLine.eMesh";
// level 2;
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
coral
// Surface-wise min and max refinement level
level (5 6);
// Resolve sharp angles
resolveFeatureAngle 30;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
coral
mode distance;
levels ((0.01 6)(0.1 5) (0.5 4) (1 2));
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the locationInMesh is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
locationInMesh (75 35 0.5);
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 5;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 3.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 30;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 5;
// Settings for the layer addition.
addLayersControls
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
coral_bottom
nSurfaceLayers 1;
// Expansion factor for layer mesh
expansionRatio 1.0;
//- Wanted thickness of final added cell layer. If multiple layers
// is the
// thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
finalLayerThickness 0.3;
//- Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.1;
//- If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
nGrow 1;
// Advanced settings
//- When not to extrude surface. 0 is flat surface, 90 is when two faces
// make straight angle.
featureAngle 30;
nRelaxIter 3;
// Number of smoothing iterations of surface normals
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
// Stop layer growth on highly warped cells
// Reduce layer growth where ratio thickness to medial
// distance is large
// Angle used to pick up medial axis points
// Create buffer region for new layer terminations
// Overall max number of layer addition iterations
nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 65;
//- Max skewness allowed. Set to <0 to disable.
//- Max concaveness allowed. Is angle (in degrees) below which concavity
// is allowed. 0 is straight face, <0 would be convex face.
// Set to 180 to disable.
maxConcave 80;
//- Minimum projected area v.s. actual area. Set to -1 to disable.
minFlatness 0.5;
//- Minimum pyramid volume. Is absolute volume of cell pyramid.
// Set to very negative number (e.g. -1E30) to disable.
minVol 1e-13;
//- Minimum face area. Set to <0 to disable.
minArea -1;
//- Minimum face twist. Set to <-1 to disable. dot product of face normal
//- and face centre triangles normal
minTwist 0.02;
//- minimum normalised cell determinant
//- 1 = hex, <= 0 = folded or flattened illegal cell
//- minFaceWeight (0 -> 0.5)
minFaceWeight 0.02;
//- minVolRatio (0 -> 1)
minVolRatio 0.01;
//must be >0 for Fluent compatibility
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- amount to scale back displacement at error points
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
and finally in attachment the stl file (in binary and ascii).
Can anybody help me?
I also tried to use gmsh to build the mesh but I'm not able to do a 2D case .
I make a 3D case but the mesh is too irregular for OpenFoam.
Thank you in advance
Silvia
gija79 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 June 18, 2011 04:36
[ICEM] wing body tutorials, problem zxin ANSYS Meshing & Geometry 8 March 22, 2011 02:05
[ICEM] [Student] Problem: Nodes Merging FALCON_SR71 ANSYS Meshing & Geometry 8 March 21, 2010 06:47
Can't get good results on ahmed body research Michael Main CFD Forum 8 September 17, 2008 13:55
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
