June 2, 2010, 03:34 |
SnappyHexMesh .stl
Jochem
I am a new user of OpenFoam. I've runned the motorBike tutorial without any problems. For my case i can use this tutorial just using an other .stl file. I've tried to do this but there are some problems that occur. When i do a blockMesh there are some errors, but it seems to work : // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from ********/constant/polyMesh/blockMeshDict" Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -333333 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -333333 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -333333 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -333333 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -333333 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -333333 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file createTopology.C at line 398 negative volume block : 0, probably defined inside-out Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 0 Number of boundary faces : 6 Number of defined boundary faces : 6 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points with scale 1 Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty There are no merge patch pairs edges Writing polyMesh End When i do the snappyHexMesh there are some fatal errors that occur : // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Read mesh in = 126.09 s Overall mesh bounding box : (-100 -50 0) (100 200 40) Relative tolerance : 1e-06 Absolute matching distance : 0.000322645 Reading refinement surfaces. Read refinement surfaces in = 0 s Reading refinement shells. Refinement level 4 for all cells inside refinementBox Read refinement shells in = 0 s Setting refinement level of surface to be consistent with shells. Checked shell refinement in = 0 s Determining initial surface intersections ----------------------------------------- Edge intersection testing: Number of edges : 48272000 Number of edges to retest : 48272000 Number of intersected edges : 11148 Calculated surface intersections in = 98.93 s Initial mesh : cells:16000000 faces:48272000 points:16272981 Cells per refinement level: 0 16000000 Adding patches for surface regions ---------------------------------- Patch Region ----- ------ ErasmusSketch2: 5 ErasmusSketch2_ascii Added patches in = 1.17 s Selecting decompositionMethod hierarchical Refinement phase ---------------- --> FOAM FATAL ERROR: Point (3 3 0.43) is not inside the mesh or on a face or edge. Bounding box of the mesh-100 -50 0) (100 200 40) From function refinementParameters::findCells(const polyMesh&) const in file autoHexMesh/autoHexMeshDriver/refinementParameters/refinementParameters.C at line 122. FOAM exiting Maybe there is some problem with my .stl file, i've used inventor to make this file. But i've runned a surfaceCheck and there were no 'illegal triangles'. Another thing i wonder is that i don't see the .stl file in Paraview. I guess you normally can see the file without doing a block or snappyHexMesh, or can't you do this? Can someone help me? Regards, Jochem Last edited by Jochem; June 3, 2010 at 02:33. |
June 2, 2010, 09:17 |
#2 | |
Convert your ASCII-type STL into a BINARY-Type STL file this helps me. PHP Code:
and ASCII.STL-> Binary.STL it really worked in both directions for me But you need "python-vtk" on your computer (apt-get install python-vtk) for debianbased distributions So put the python code in a "file", edit the input and output path, do not forget "chmod a+x file" and run ./file now paraview or meshlab should show the Binary-STL-File. elvis elvis |
June 2, 2010, 11:24 |
Jochem
Hi Elvis,
Thanks a lot for the help, i will try to use your "workaround" to solve my problem. I will let you know when i've succeed in solving my problem. Regards, Jochem |
June 2, 2010, 13:20 |
Philip Cardiff
Rep Power: 34 |
Hi Jochem,
Could you post your blockMeshDict too? Having negative volume cells is not a good thing, and could cause many problems. Philip C Last edited by bigphil; June 3, 2010 at 06:11. |
June 2, 2010, 16:24 |
Jochem
I've been abled to find a solution for my problem. The dimension of my .stl file where to large. The convertion from mm in inventor to meters gave the error. The .stl file was bigger then the blockMesh i did, i guess that's why i have some negative values. Another issue was that i've saved the .stl file using another name. I thoughtthat i've change this trough all files of the case but apparently this was not so. So i've saved my .stl file to motorBike.stl. Anyway thanks for the quick responses and the help. Regards, Jochem |
August 3, 2012, 04:29 |
Roman Gášpár
Hello guys. I have similar problem.
I make a cube with blockMeshDict (check it->Mesh OK) and I open it in ParaFoam. After that i open my .stl file (see pic.) It seem to be everithing fine. In next step I make a surfaceCheck and there are no illegal triangles. I run the snappyHexMesh and... Refinement phase ---------------- --> FOAM FATAL ERROR: Point (3 3 0.43) is not inside the mesh or on a face or edge. Bounding box of the mesh-0.5 -0.4 -0.5) (1.5 0.4 0.5) no other errors... BUT!!!! in .stl file is no coordinate (3 3 0.43) do you have any suggestions? thanks a lot for reading my reply Roman |
August 3, 2012, 05:25 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Roman and welcome to the forum!
Try this coordinate: (3.2412 3.25345 0.431351234) This way it's a lot harder to fall right on top of a cell face or edge! Best regards, Bruno
August 3, 2012, 06:20 |
Roman Gášpár
Thanks for help and welcome but I solved the problem by myself
in "snappyHexMeshDict" is a part // Mesh selection // ~~~~~~~~~~~~~~ // After refinement patches get added for all refinementSurfaces and // all cells intersecting the surfaces get put into these patches. The // section reachable from the locationInMesh is kept. // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (0 0 0); <---- Here is default (3 3 0.43) and you must use coordinates which are inside your cube (in my case is (0 0 0) ) !!!! and it will works Last edited by roman.gaspar; August 9, 2012 at 02:50. |
September 21, 2016, 10:31 |
Point is not inside the mesh
Mauricio
Rep Power: 10 |
Hello guys and gals,
Coming back to this old thread, I was playing a bit with snappyHexMesh and I got the popular error: 'Point (0.002131 0.001123 0.082321) is not inside the mesh or on a face or edge. Bounding box of the mesh-0.03 -0.03 -0.01) (0.03 0.03 0.17)'. I am trying to use snappyHexMesh for meshing a counter flow heat exchanger to validate a conjugate heat transfer solver. Attached go my blockMesh and my SnappyHexMesh Dicts. blockMeshDict.txt snappyHexMeshDict.txt Looking at the geometry everything seems fine, the STL bodies inside the box: photoSnappy.png So far I have tried to: -> Try with different points inside the bounding box and geometry. -> Make the bounding box bigger -> translate the STL files so that all points are positive: surfaceTransformPoints -translate '(x x x)' ... -> pass the STL files to binary: http://www.cfd-online.com/Forums/ope...tml#post261388 response #2. However I seem not to be able to overcome the error. Any ideas? Thanks in advance! Mauricio. Last edited by mauri_tano; September 22, 2016 at 05:46. |
September 22, 2016, 21:01 |
When you create your blockMesh, are there negative volume cells? Are some faces/cells twisted inside out? (This would be output in the log for blockMesh as a warning). If you have tried multiple locationInMesh points all of which are within your bounding box and you still have this issue, then I am tempted to think that it is the above mentioned point. Check your blockMesh log to confirm. If it is indeed the case that you have that inside-out twisted cells/faces, then you will need to reorder the vertices making up the blockMesh to avoid this. Hope this helps. Cheers, Antimony |
September 23, 2016, 04:26 |
Careful with the negative volumes in blockMesh when using snappyHexMesh
#11 |
Mauricio
Rep Power: 10 |
Hello Antimony,
Thanks for your response, indeed I had inside-out twisted cells. As a matter of fact my whole domain was twisted inside out . I've totally passed this over, my bad. Thanks again! Mauricio. |
[Gmsh] .stl from GMSH in SnappyHexMesh | vainilreb | OpenFOAM Meshing & Mesh Conversion | 7 | March 19, 2020 08:54 |
[snappyHexMesh] snappyHexMesh .stl generate extra boundary | gsq | OpenFOAM Meshing & Mesh Conversion | 0 | April 21, 2018 06:03 |
[snappyHexMesh] SnappyHexMesh fails to create patches of .stl files | WernerW | OpenFOAM Meshing & Mesh Conversion | 4 | September 26, 2017 00:59 |
[snappyHexMesh] snappyHexMesh does not create boundary patches from .stl files | bug_or_feature | OpenFOAM Meshing & Mesh Conversion | 7 | August 30, 2016 19:18 |
multiple .stl in snappyHexMesh | jki | OpenFOAM Pre-Processing | 1 | August 2, 2014 13:07 |
