A beginner question
Hello all,
I am a CFD person but have no experince with OPENFOAM at all. Could you please let me know the following? 1) How long it takes to learn and be able to run a simple flow problem (e.g., flow past cylinder), including mesh making? 2) Can I use a Fortran code to call OPENFOAM? Your input is greatly appreciated. Go and see |
The story changes if you have to change the code, and at that point I would recommend to either take a course from OpenFOAM developers or be prepared to spend a good amount of time exploring and learning the code details. Quote:
Best, |
I mean to call executables, this post is from me to thread " How to interface a Fortran thermodynamic tool with OpenFOAM?" __________________________________________________ _______ Hi, I have couple of fortran.90 subroutines which I would like to call from OpenFOAM1.6. What I know direct call of fortran subroutine from c++ is not good. Thus, one has to have C interface to routines and some more technical difficulties as, fortran stores rowwise C stores columnwise :confused: Whatever, these are general problems of C++ and Fortran mixing. My questions are more OpenFOAM specific: 1) What should be the compiled fortran source codes, dynamic library, shared objects (.so), objects (.o) ... ? If more than one is good, which one performs better? 2) How should be this "executables" (compiled files) linked to OpenFOAM, let's say scalarFoam? How should the <file> and <options> in Make folder be modified? Please no suggestion like "why don't you rewrite your subroutines in C++" ;-) All the best, @ Cyp: You see, I am chasing you ;-) __________________________________________________ _______ Any idea? Cheers, http://www.cfd-online.com/Forums/ima...ser_online.gif http://www.cfd-online.com/Forums/ima...reputation.gif http://www.cfd-online.com/Forums/ima...ons/report.gif http://www.cfd-online.com/Forums/ima...c/progress.gif http://www.cfd-online.com/Forums/ima...ttons/edit.gif |
