-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Discretizer questions (http://www.cfd-online.com/Forums/openfoam/76762-discretizer-questions.html)
be_inspired June 3, 2010 15:09
I am trying to use discretizer to mesh over some complex curves ( which define a surface) defined with several points.
Is it possible to create a complex surface with discretizer between two different curves? ( line and curve and obtain a "torsioned" surface). My objective is to create a script for discretizer where points are imported, curves are created, surfaces and then the volume is discretized.
Could someone tell me about the way dz file is created? I do not understand the way in which line is created with two points with the use of * at some points of each line.
Thank you
Marcelino
elvis June 5, 2010 02:37
Discretizer's spiritus rector has a email account
bjorn (dot) bergqvist (AT) gmail (dot) com
I hope it is okay to copy email adress from http://www.discretizer.org
=>March 31, 2010, lets twitter on #openfoam
The Master would like to hear some twitter on #openfoam! See you on: http://twitter.com/discretizer
in this forum
user bjornthe http://www.cfd-online.com/Forums/members/bjornthe.html
i can not help you more as, i am a beginner to Discretizer
I'm mainly interested in SHM gui and therefore Discretizer::Setup is s.th i want to use.
elvis
bjornthe June 9, 2010 04:15
Currently it is not possible to do what you want.
Open the *.dtz file in a spreadsheet. Then you se different objects are associated in columns.
So if something is referenced with a *, it means it is associated with that object. If it would have been p0. Then it is the internal object p0 of that object... maybe I explain it with pictures one day.
The type of thing you want to do would be interesting to implement in Discretizer.
Regards
Björn Bergqvist
semaviso June 4, 2011 09:46
How to creater a Porous media in a cylinder
Hello everyone
I just discover the discretizer tool and have tried to creat a few cubes and setup cases. I would like some1 to show/help me with creating porous zones in these cubes and how to create a cylindrical geometry with porous zones.
Thank u in advance, I think this tool is really helpful.
