Home > Forums > OpenFOAM
Valve open/closed
Old   June 17, 2010, 07:45
Default Valve open/closed
FabOr is on a distinguished road
Hi all,
i try to simulate a flow in a pipe.
in the middle of the pipe, i try to implement a valve which should open when the pressure difference is high enough otherwise it should be closed.
so, are there any examples in the tutorials where valves are used?
how can i implement a valve?
thx for reading and i hope you make some suggestions.
FabOr is offline   Reply With Quote
Old   June 17, 2010, 08:23
Elvis
elvis will become famous soon enough
Originally Posted by FabOr View Post
Are there any examples in the tutorials where valves are used?
There are valves in the engine section
https://openfoam-extend.svn.sourcefo...e/engineValve/
https://openfoam-extend.svn.sourcefo...elEngineValve/
https://openfoam-extend.svn.sourcefo...sSlidingValve/
https://openfoam-extend.svn.sourcefo.../thoboisValve/
in Case you use OpenFOAM (extend/dev)
http://repo.or.cz/w/OpenFOAM-1.6.x.g...ne/engineValve
if you use OF1.6.x-GIT
elvis
elvis is offline   Reply With Quote
Old   June 18, 2010, 05:27
Hi thx for your answer.
i am new to OF so i donīt understand those scripts at all.
my problem is quite simple, i think.
must i really create those scripts or are there any easier ways?
or what elements can be copied for this problem?
thx for your patience
Old   June 18, 2010, 05:46
Elvis
Well there are also the tutorials that deal with this stuff.
If you want to simulate s.th. with a real physical meaning (and behavior of an valve) you should take a deeper look into this stuff.
An alternative might be a Boundary Condition that behaves according to your valve but not much easier to implement in my opinion.
Are you doing a real world engineering problem or is your stuff going more in the gaming direction? In case of gaming take a look at blender and its cfd capabilaties. Not bad at all!
To read more the about the "advanced" stuff you want to do http://web.student.chalmers.se/group...ynamicMesh.pdf
At the workshop in Gothenburg the "advanced users" gonna work on OF's dynamic mesh capabilaties that includes valves. Not easy for a beginner!
elvis
Thread Tools
Trackbacks are On
Large Valve Flow Analysis - Inflation Problem sercan85 ANSYS Meshing & Geometry 2 June 1, 2010 14:02
How to simulate valve with pressure BC? Luk FLUENT 8 June 20, 2006 08:06
Valve action Hrvoje Jasak (Hjasak) OpenFOAM Running, Solving & CFD 0 January 13, 2005 14:23
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 15:09
