-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   dnsFoam divergent solution (http://www.cfd-online.com/Forums/openfoam/77445-dnsfoam-divergent-solution.html)
NorbertB June 23, 2010 05:56
Hello everyone.
I have been working with dnsFoam, trying to simulate a flow between 2 walls. In a second time, I would like to focus on the boundary layer (laminar near the inlet, then transient and finally fully turbulent).
My simulations are three-dimensional, as I read on this forum a 2-D simulation does not fit with the physics.
My solution blows up after a few iterations. Here are some details about the case:
I created the mesh with blockMesh. It is a 64*64*64 mesh with 2 walls (top and bottom). I will refine the mesh but at present I try to run successfully this case.
I am using 4 patches : 1 inlet, 1 outlet and front and back faces.
Inlet velocity is 2m/s and I set the same velocity for the outlet as a test, since the primitive type "calculated" is not accepted.
Pressure is zeroGradient for every patches.
When i run my case this is the problem i am having:
Starting time loop
Time = 0.025
Number of forced K = 12
k(0.025) = 0
epsilon(0.025) = 0.03072
U.f(0.025) = 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 3.6888e-10, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 3.23237e-06, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 3.04559e-06, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 9.60124e-07, No Iterations 105
time step continuity errors : sum local = 3.05364e-07, global = 2.54977e-19, cumulative = 2.54977e-19
ExecutionTime = 35.17 s ClockTime = 37 s
Time = 0.05
k(0.05) = 7.03496
epsilon(0.05) = 0.10727
U.f(0.05) = 0.00848164
DILUPBiCG: Solving for Ux, Initial residual = 0.942152, Final residual = 6.78512e-06, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 0.447296, Final residual = 5.41539e-06, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0.48381, Final residual = 5.13443e-06, No Iterations 2
DICPCG: Solving for p, Initial residual = 0.512288, Final residual = 7.8354e-07, No Iterations 124
time step continuity errors : sum local = 5.0736e-07, global = 3.11369e-19, cumulative = 5.66345e-19
ExecutionTime = 67.12 s ClockTime = 70 s
Time = 0.075
k(0.075) = 7.10567
epsilon(0.075) = 0.0846326
U.f(0.075) = 0.0171798
DILUPBiCG: Solving for Ux, Initial residual = 0.66248, Final residual = 1.28027e-07, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0.478977, Final residual = 2.44826e-06, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 0.390294, Final residual = 2.05455e-06, No Iterations 3
DICPCG: Solving for p, Initial residual = 0.494019, Final residual = 9.00221e-07, No Iterations 89
time step continuity errors : sum local = 1.2928e-06, global = -4.11385e-20, cumulative = 5.25207e-19
ExecutionTime = 94.88 s ClockTime = 100 s
Time = 0.1
k(0.1) = 29.9182
epsilon(0.1) = 0.428527
U.f(0.1) = 0.0275886
DILUPBiCG: Solving for Ux, Initial residual = 0.599916, Final residual = 4.98354e-06, No Iterations 29
DILUPBiCG: Solving for Uy, Initial residual = 0.674577, Final residual = 6.3118e-06, No Iterations 35
DILUPBiCG: Solving for Uz, Initial residual = 0.651333, Final residual = 8.71581e-06, No Iterations 32
DICPCG: Solving for p, Initial residual = 0.415806, Final residual = 5.96243e-07, No Iterations 101
time step continuity errors : sum local = 1.9221e-06, global = -5.15559e-19, cumulative = 9.64744e-21
ExecutionTime = 157.27 s ClockTime = 166 s
Time = 0.125
k(0.125) = 282.499
epsilon(0.125) = 4.69267
U.f(0.125) = 0.0176418
DILUPBiCG: Solving for Ux, Initial residual = 0.733885, Final residual = 0.347319, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = 0.907019, Final residual = 0.69476, No Iterations 1001
DILUPBiCG: Solving for Uz, Initial residual = 0.905652, Final residual = 1.06002, No Iterations 1001
DICPCG: Solving for p, Initial residual = 0.892429, Final residual = 9.26503e-07, No Iterations 136
time step continuity errors : sum local = 2.51378e-05, global = 1.83659e-17, cumulative = 1.83755e-17
ExecutionTime = 1350.73 s ClockTime = 1571 s
Time = 0.15
k(0.15) = 121341
epsilon(0.15) = 14327.3
U.f(0.15) = 0.497558
**** I stopped here, clearly diverging ****
As you can see, global and cumulative errors remain acceptable but k and epsilon diverge in all my tests. I have looked through the forum for similar problems but still cannot fix my problem. I would be very greatful for any suggestions to improve my case.
Also, is there any relevant boundary condition for the outlet ?
arjun June 23, 2010 07:38
"Pressure is zeroGradient for every patches."
if pressure is zero gradient then pressure equation is singular for incompressible case.
It might be reason for your problems, try fixed pressure at outlet.
(ideally solver should take care of such situation).
NorbertB June 24, 2010 04:17
Hi arjun,
Thank you very much for your reply, I checked it out but it seems dnsFoam does not care about that since a DNS does not make incompressible assumption.
However, I realized that my deltaT was not small enough to keep a courant number below 1. So I changed it and now the solution converges. I should have know it ...
Now I wonder which boundary conditions could fit better to my problem, especially for the inlet/outlet.
If anybody has got an idea.
