-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Friction coefficients using icoFoam (http://www.cfd-online.com/Forums/openfoam/77456-friction-coefficients-using-icofoam.html)
wjarrah June 23, 2010 10:22
Hello everyone,
I need to plot the friction coefficient using icoFoam solver on a flat plate.
I tried to add the following lines at the end of /system/controlDict, but an error appears when calling "icoFoam" :
functions
forces
type forces;
functionObjectLibs ("libforces.so");
patches (wall);
rhoInf 1000;
CofR (0 0 0);
forceCoeffs
type forceCoeffs;
patches (wall);
rhoInf 1000;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 0);
magUInf 0.13;
lRef 1;
Aref 1;
The error :
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Courant Number mean: 0 max: 0.052
Starting time loop
keyword outputControl is undefined in dictionary "::functions::forces"
file: ::functions::forces from line 59 to line 63.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 388.
FOAM exiting
Can someone help me with this problem please ?
(Maybe there is another way to output the friction coefficient ?)
Thanks
Aloex August 21, 2010 05:25
I have the same error after starting "icoFoam".
Is it possible that it is not sufficient to make the entry in the system/controlDict for the forces and force coefficients like wjarrah it done? Must I change also other files from the solver or so?
Thanks for your help!
Alex
Aloex August 21, 2010 06:18
I solved the problem with the help of other threads and forums. It is not necessary to change anything else then the controlDict. Here are the additional lines for the controlDict:
functions
forces
type forces;
rhoInf 1.0;
patches ( ELLIPSOID.1 );
CofR (0 0 0);
outputControl timeStep;
outputInterval 1;
forceCoeffs
// rhoInf - reference density
// CofR - Centre of rotation
// dragDir - Direction of drag coefficient
// liftDir - Direction of lift coefficient
// pitchAxis - Pitching moment axis
// magUinf - free stream velocity magnitude
// lRef - reference length
// Aref - reference area
type forceCoeffs;
patches (ELLIPSOID.1);
rhoName rhoInf;
rhoInf 1.0;
CofR (0 0 0);
liftDir (0 0 1);
dragDir (0 1 0);
pitchAxis (0 0 1);
magUInf 0.1;
lRef 0.0004; // ellipsoid max diameter
Aref 6.283e-8; //projected area from ellipsoid
outputInterval 1;
It creates a directory for the forces and force coefficients in your case.
Alex
