[Commercial meshers] cyclic multiedge BC
Old   June 16, 2010, 03:26
Default cyclic multiedge BC
Giovanni Caramia
karamiag is on a distinguished road
Hi guys,
I have a 2D mesh made with gambit and I have to set periodicity between inlet and outlet but both of them have more then one edge (in gambit). Using fluentMeshToFoam works if inlet and outlet have only one edge but if there is more than one it does not : in particular runnning checkMesh I receive the "possible face ordering problem" message.
Any one has already solved this problem?
Thanks
karamiag is offline   Reply With Quote
Old   June 30, 2010, 11:24
Giovanni Caramia
Ok, it worked and this is what I have done. I had a domain like this
L3 |-------| R3
L2 |-------| R2
L1 |-------| R1
With createPatch utility, I merged edge L1 and L2 obtaining a single generic patch called L1L2, after this I merged edge L1L2 and L3 obtaining a single patch called L1L2L3; the same on the other hand, obtaining a single patch called R1R2R3. After this, I used createPatch utility to make L1L2L3 periodic with R1R2R3.
This is createPatchDict file for merging L1 and L2:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object createPatchDict;
matchTolerance 1E-7;
pointSync true;
patches
name L1L2;
type patch;
dictionary
type patch;
constructFrom patches;
patches (L1 L2);
This is my final createPatchDict file:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
pointSync true;
patches
name period;
type cyclic;
dictionary
type cyclic;
patches (L1L2L3 R1R2R3);
Hope this can help.
Bye
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 08:03
LES in OF 3.0.1, no Output for nuSgs Mirage OpenFOAM Programming & Development 1 October 4, 2016 18:00
Cyclic Boundary Condition Errors? nyflyer OpenFOAM Running, Solving & CFD 2 April 26, 2016 14:14
Possible createPatch/createBaffles bug? simpomann OpenFOAM Bugs 2 July 15, 2014 07:07
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
