Axisymmetric Grid
Does any have a sample blockMeshDict to create mesh for a cylinder with an inlet pipe on side?
blockMesh is a rather easy and - dare I say it - fun tool to use. Read the blockMesh guide (http://www.openfoam.com/docs/user/blockMesh.php) and dip your feet in the water. If that doesn't work out, repost and I'll see what I can do.
best regards and best of luck, Matt |
The following is a cylinder mesh that I have been using to simulate flow through a pipe:
FoamFile Matt |
HI matt,
thanks a ton. and as you said it is a very good tool. I was trying to modify your file to inlcude an annular inlet and merge all the outlet faces in 1 sinle outlet patch. But I do get error. Can you please help me and if possible let me know if I am missing something. Thanks, Na File: FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; vertices ( /*Inlet Square*/ (0.5 0 0) (0 0.5 0) (-0.5 0 0) (0 -0.5 0) /*Inlet Inner Circle*/ (1.0 0 0) (0 1.0 0) (-1.0 0 0) (0 -1.0 0) /*Inlet Inner Annulus*/ (1.5 0 0) (0 1.5 0) (-1.5 0 0) (0 -1.5 0) /*Inlet Outer Circle*/ (10 0 0) (0 10 0) (-10 0 0) (0 -10 0) /*Outlet Square*/ (0.5 0 180) (0 0.5 180) (-0.5 0 180) (0 -0.5 180) /*Outlet Inner Circle*/ (1.0 0 180) (0 1.0 180) (-1.0 0 180) (0 -1.0 180) /*Outlet Inner Annulus*/ (1.5 0 180) (0 1.5 180) (-1.5 0 180) (0 -1.5 180) /*Outlet Outer Circle*/ (10 0 180) (0 10 180) (-10 0 180) (0 -10 180) ); blocks ( /*Square Block*/ hex (0 1 2 3 16 17 18 19) (20 20 20) simpleGrading (1 1 1) /*Inner Circle Blocks*/ hex (0 4 5 1 16 20 21 17) (20 20 20) simpleGrading (1 1 1) hex (1 5 6 2 17 21 22 18) (20 20 20) simpleGrading (1 1 1) hex (2 6 7 3 18 22 23 19) (20 20 20) simpleGrading (1 1 1) hex (3 7 4 0 19 23 20 16) (20 20 20) simpleGrading (1 1 1) /*Inner Annulus Blocks*/ hex (4 8 9 5 20 24 25 21) (10 10 10) simpleGrading (1 1 1) hex (5 9 10 6 21 25 26 22) (10 10 10) simpleGrading (1 1 1) hex (6 10 11 7 22 26 27 23) (10 10 10) simpleGrading (1 1 1) hex (7 11 8 4 23 27 24 20) (10 10 10) simpleGrading (1 1 1) /*Outer Circle Blocks*/ hex (8 12 13 9 24 28 29 25) (6 20 20) simpleGrading (1 1 1) hex (9 13 14 10 25 29 30 26) (6 20 20) simpleGrading (1 1 1) hex (10 14 15 11 26 30 31 27) (6 20 20) simpleGrading (1 1 1) hex (11 15 12 8 27 31 28 24) (6 20 20) simpleGrading (1 1 1) ); edges ( /*Inlet Inner Circle*/ arc 4 5 (0.707106781 0.707106781 0) arc 5 6 (-0.707106781 0.707106781 0) arc 6 7 (-0.707106781 -0.707106781 0) arc 7 4 (0.707106781 -0.707106781 0) /*Inlet Annulus Circle*/ arc 8 9 (1.060660171 1.060660171 0) arc 9 10 (-1.060660171 1.060660171 0) arc 10 11 (-1.060660171 -1.060660171 0) arc 11 8 (1.060660171 -1.060660171 0) /*Inlet Outer Circle*/ arc 12 13 (7.071067811 7.071067811 0) arc 13 14 (-7.071067811 7.071067811 0) arc 14 15 (-7.071067811 -7.071067811 0) arc 15 12 (7.071067811 -7.071067811 0) /*Outlet Inner Circle*/ arc 20 21 (0.707106781 0.707106781 180) arc 21 22 (-0.707106781 0.707106781 180) arc 22 23 (-0.707106781 -0.707106781 180) arc 23 20 (0.707106781 -0.707106781 180) /*Outlet Annulus Circle*/ arc 24 25 (1.060660171 1.060660171 180) arc 25 26 (-1.060660171 1.060660171 180) arc 26 27 (-1.060660171 -1.060660171 180) arc 27 24 (1.060660171 -1.060660171 180) /*Outlet Outer Circle*/ arc 28 29 (7.071067811 7.071067811 180) arc 29 30 (-7.071067811 7.071067811 180) arc 30 31 (-7.071067811 -7.071067811 180) arc 31 28 (7.071067811 -7.071067811 180) ); patches ( patch inletInner ( /*Inlet Square*/ (0 1 2 3) /*Inlet Inner Circle*/ (0 4 5 1) (1 5 6 2) (2 6 7 3) (3 7 4 0) ) patch outlet ( /*Outlet Square*/ (16 17 18 19) /*Outlet Inner Circle*/ (16 20 21 17) (17 21 22 18) (18 22 23 19) (19 23 20 16) /*Outlet Annulus Circle*/ (20 24 25 21) (21 25 26 22) (22 26 27 23) (23 27 24 20) /*Outlet outer Circle*/ (24 28 29 25) (25 29 30 26) (26 30 31 27) (27 31 28 24) ) patch inletAnnulus ( /*Inlet Annulus Strip*/ (4 8 9 5) (5 9 10 6) (6 10 11 7) (7 11 8 4) ) wall inletOuter ( /*Inlet Outer Circle*/ (8 12 13 9) (9 13 14 10) (10 14 15 11) (11 15 12 8) ) wall tube1 ( (12 28 29 13) ) wall tube2 ( (13 29 30 14) ) wall tube3 ( (14 30 31 15) ) wall tube4 ( (15 31 28 12) ) ); mergePatchPairs ( ); Error I get is: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/mnt/raid/home/na/OpenFOAM/na-1.6/run/TestFoam/BYU/constant/polyMesh/blockMeshDict" Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 24 Number of boundary faces : 30 Number of defined boundary faces : 30 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list Inconsistent number of faces between block pair 1 and 5#0 Foam::error::printStack(Foam::Ostream&) in "/home/na/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::exit(int) in "/home/na/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::Ostream& Foam::operator<< <Foam::error, int>(Foam::Ostream&, Foam::errorManipArg<Foam::error, int>) in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #3 Foam::blockMesh::createMergeList() in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #4 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #5 main in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #6 __libc_start_main in "/lib/libc.so.6" #7 _start in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" From function blockMesh::createMergeList() in file createMergeList.C at line 196. FOAM aborting (FOAM_ABORT set) Inconsistent number of faces between block pair 1 and 5#0 Foam::error::printStack(Foam::Ostream&) in "/home/na/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::exit(int) in "/home/na/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::Ostream& Foam::operator<< <Foam::error, int>(Foam::Ostream&, Foam::errorManipArg<Foam::error, int>) in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #3 Foam::blockMesh::createMergeList() in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #4 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #5 main in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #6 __libc_start_main in "/lib/libc.so.6" #7 _start in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #0 Foam::error::printStack(Foam::Ostream&) in "/home/na/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/na/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::error::exit(int) in "/home/na/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #3 Foam::Ostream& Foam::operator<< <Foam::error, int>(Foam::Ostream&, Foam::errorManipArg<Foam::error, int>) in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #4 Foam::blockMesh::createMergeList() in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #5 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #6 main in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #7 __libc_start_main in "/lib/libc.so.6" #8 _start in "/home/na/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" From function blockMesh::createMergeList() in file createMergeList.C at line 196. FOAM aborting (FOAM_ABORT set) |
You are running into this error because your mesh in defined inconsistently. You have defined two different blocks sharing the face 4 5 21 20, the first one
hex (0 4 5 1 16 20 21 17) (20 20 20) simpleGrading (1 1 1) Code:
hex (4 8 9 5 20 24 25 21) (10 10 10) simpleGrading (1 1 1) Regards, Stefan |
Hi Stefan,
Thanks. After makingmesh resolution consistent on both sides, I am able to create the mesh. But maybe I am missing something in understanding that if I take a slice and look at the cross-section, then I do not see hex-mesh. It appears that the mesh is tets, even though I am specifying hex-mesh. I checked this by taking a slice along the axis of the cylinder. Even if you look at the domain with option "surface with edges" it shows the tet-mesh. Can you recommend what is to be done to get a compelte hex mesh. Thanks, Nir The corrected file is below: -------------------------------- | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.0 | | \\ / A nd | Web: http://www.openfoam.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; vertices ( /*Inlet Square*/ (0.25 0 0) (0 0.25 0) (-0.25 0 0) (0 -0.25 0) /*Inlet Inner Circle*/ (0.655 0 0) (0 0.655 0) (-0.655 0 0) (0 -0.655 0) /*Inlet Inner Annulus*/ (1.435 0 0) (0 1.435 0) (-1.435 0 0) (0 -1.435 0) /*Inlet Outer Circle*/ (4 0 0) (0 4 0) (-4 0 0) (0 -4 0) /*Outlet Square*/ (0.25 0 180) (0 0.25 180) (-0.25 0 180) (0 -0.25 180) /*Outlet Inner Circle*/ (0.655 0 180) (0 0.655 180) (-0.655 0 180) (0 -0.655 180) /*Outlet Inner Annulus*/ (1.435 0 180) (0 1.435 180) (-1.435 0 180) (0 -1.435 180) /*Outlet Outer Circle*/ (4 0 180) (0 4 180) (-4 0 180) 36,5 0% (0 4 180) (-4 0 180) (0 -4 180) ); blocks ( /*Square Block*/ hex (0 1 2 3 16 17 18 19) (6 6 20) simpleGrading (1.1 1.1 1) /*Inner Circle Blocks*/ hex (0 4 5 1 16 20 21 17) (6 6 20) simpleGrading (1.1 1.1 1) hex (1 5 6 2 17 21 22 18) (6 6 20) simpleGrading (1.1 1.1 1) hex (2 6 7 3 18 22 23 19) (6 6 20) simpleGrading (1.1 1.1 1) hex (3 7 4 0 19 23 20 16) (6 6 20) simpleGrading (1.1 1.1 1) /*Inner Annulus Blocks*/ hex (4 8 9 5 20 24 25 21) (6 6 20) simpleGrading (1.1 1.1 1) hex (5 9 10 6 21 25 26 22) (6 6 20) simpleGrading (1.1 1.1 1) hex (6 10 11 7 22 26 27 23) (6 6 20) simpleGrading (1.1 1.1 1) hex (7 11 8 4 23 27 24 20) (6 6 20) simpleGrading (1.1 1.1 1) /*Outer Circle Blocks*/ hex (8 12 13 9 24 28 29 25) (6 6 20) simpleGrading (1.1 1.1 1) hex (9 13 14 10 25 29 30 26) (6 6 20) simpleGrading (1.1 1.1 1) hex (10 14 15 11 26 30 31 27) (6 6 20) simpleGrading (1.1 1.1 1) hex (11 15 12 8 27 31 28 24) (6 6 20) simpleGrading (1.1 1.1 1) ); edges ( /*Inlet Inner Circle*/ arc 4 5 (0.463154942 0.463154942 0) arc 5 6 (-0.463154942 0.463154942 0) arc 6 7 (-0.463154942 -0.463154942 0) arc 7 4 (0.463154942 -0.463154942 0) /*Inlet Annulus Circle*/ arc 8 9 (1.014698231 1.014698231 0) arc 9 10 (-1.014698231 1.014698231 0) arc 10 11 (-1.014698231 -1.014698231 0) arc 11 8 (1.014698231 -1.014698231 0) /*Inlet Outer Circle*/ arc 12 13 (2.828427124 2.828427124 0) arc 13 14 (-2.828427124 2.828427124 0) arc 14 15 (-2.828427124 -2.828427124 0) arc 15 12 (2.828427124 -2.828427124 0) /*Outlet Inner Circle*/ arc 20 21 (0.463154942 0.463154942 180) arc 21 22 (-0.463154942 0.463154942 180) arc 22 23 (-0.463154942 -0.463154942 180) arc 23 20 (0.463154942 -0.463154942 180) /*Outlet Annulus Circle*/ arc 24 25 (1.014698231 1.014698231 180) arc 25 26 (-1.014698231 1.014698231 180) arc 26 27 (-1.014698231 -1.014698231 180) arc 27 24 (1.014698231 -1.014698231 180) /*Outlet Outer Circle*/ arc 28 29 (2.828427124 2.828427124 180) arc 29 30 (-2.828427124 2.828427124 180) arc 30 31 (-2.828427124 -2.828427124 180) 65,5 43% arc 29 30 (-2.828427124 2.828427124 180) arc 30 31 (-2.828427124 -2.828427124 180) arc 31 28 (2.828427124 -2.828427124 180) ); patches ( patch inletInner ( /*Inlet Square*/ (0 1 2 3) /*Inlet Inner Circle*/ (0 4 5 1) (1 5 6 2) (2 6 7 3) (3 7 4 0) ) patch outlet ( /*Outlet Square*/ (16 17 18 19) /*Outlet Inner Circle*/ (16 20 21 17) (17 21 22 18) (18 22 23 19) (19 23 20 16) /*Outlet Annulus Circle*/ (20 24 25 21) (21 25 26 22) (22 26 27 23) (23 27 24 20) /*Outlet outer Circle*/ (24 28 29 25) (25 29 30 26) (26 30 31 27) (27 31 28 24) ) patch inletAnnulus ( /*Inlet Annulus Strip*/ (4 8 9 5) (5 9 10 6) (6 10 11 7) (7 11 8 4) ) wall inletOuter ( /*Inlet Outer Circle*/ (8 12 13 9) (9 13 14 10) (10 14 15 11) (11 15 12 8) ) wall tube1 ( (12 28 29 13) ) 128,5 85% (12 28 29 13) ) wall tube2 ( (13 29 30 14) ) wall tube3 ( (14 30 31 15) ) wall tube4 ( (15 31 28 12) ) ); mergePatchPairs ( ); |
