June 29, 2010, 09:32 |
Coakley q-omega turbulence model
David Boger
Rep Power: 17 |
Some users may be interested to know that I have added Coakley's q-omega two-equation turbulence model to the Breeder_1.5 branch of the SVN repository. This is likely to be of interest mainly to users coming from other CFD codes where the q-omega model was used, U2NCLE being the primary example.
This is currently a low-Reynolds number or "no-slip" formulation (where q should be fixedValue 0 and omega should be zeroGradient at the wall), although I hope I will find time soon to add generalized wall functions. The q-omega equations are essentially derived by a simple change of variables from the Jones-Launder k-epsilon model, but formulating the equations in terms of q rather than k helps to eliminate the need for a low-Reynolds-number dissipation term (Coakley, AIAA 83-1693). The formulation also leads to finite values of omega at the wall, helping to make the model relatively robust numerically. The source code and a flat plate tutorial test case can be obtained from the openfoam-extend SVN repository using the following command:
David A. Boger |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
Adding a Turbulence Model | doug | OpenFOAM Running, Solving & CFD | 11 | May 21, 2018 13:54 |
SimpleFoam case with SpalartAllmaras turbulence model implemented | nedved | OpenFOAM Running, Solving & CFD | 2 | November 30, 2014 22:43 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 06:12 |
