July 2, 2010, 03:16 |
SIGFPE unless deltaT extremely small
Ondra Mican
Hello all!
I am trying to solve the following system in 2D: dc1/dt = b*c2*c2 + L1 laplace c1 + n L4 laplace phi dc2/dt = 2a - 2b*c2*c2 + L3 laplace c1 + L4 laplace phi laplace phi = - L2 * c2 for which I made a straightforward solver like this: for (runTime++; !runTime.end(); runTime++) { Info<< "Time = " << runTime.timeName() << nl << endl; # include "readSIMPLEControls.H" scalar maxResidual = 0; for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { fvScalarMatrix EqC1 ( fvm::ddt(C1) == b*C2*C2 + fvm::laplacian(L1, C1) + fvc::laplacian(n*L4, elstat_pot) ); EqC1.relax(); scalar eqnResidualC1 = EqC1.solve().initialResidual(); maxResidual = max(eqnResidualC1, maxResidual); fvScalarMatrix EqC2 ( fvm::ddt(C2) == 2*a-2*b*C2*C2 + fvc::laplacian(L3, C1) + fvc::laplacian(L4, elstat_pot) ); EqC2.relax(); scalar eqnResidualC2 = EqC2.solve().initialResidual(); maxResidual = max(eqnResidualC2, maxResidual); fvScalarMatrix EqPot ( fvm::laplacian(elstat_pot) == -L2*C2 ); EqPot.relax(); scalar eqnResidualPot = EqPot.solve().initialResidual(); maxResidual = max(eqnResidualPot, maxResidual); } # include "write.H" Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } It works fine with some cases, but crashes for others. For example when I use the following values of parameters: a=200 b=6.324555e-6 n=1.5 L1=6.0e-10 L2=1.089733454e+9 L3=1.19762e-10 L4=3.10929e-5 the solver works pretty fine. But when I raise L2 to 1.08973e+15 (which is physically more reasonable), only a few time levels are computed and then the solver crashes saying #0 Foam::error::printStack(Foam::Ostream&) in "/home/sporit/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/sporit/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/sporit/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const in "/home/sporit/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/sporit/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/sporit/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/sporit/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so" #8 main in "/home/sporit/OpenFOAM/sporit-1.6/applications/bin/linuxGccDPOpt/cellFoamForum" #9 __libc_start_main in "/lib/libc.so.6" #10 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/sporit/OpenFOAM/sporit-1.6/applications/bin/linuxGccDPOpt/cellFoamForum" Floating point exception(SIGFPE) I've tried various numerical schemes as well as various linear-solvers, but the only settings that really helps is to reduce deltaT. However, for some values (like the ones shown above) deltaT has to be set to something like 5e-11 which makes the process extremely slow. Any advice or recommendation how to speed up the computation in this case will be highly appreciated. Thanks a lot in advance, Ondra |
why did Time step is too small in stiffbs? | satum | FLUENT | 1 | December 10, 2012 10:15 |
Floating point exception error with small DeltaT | rassilon | OpenFOAM Running, Solving & CFD | 19 | September 2, 2009 08:39 |
problems with turbFoam (small deltaT) | sven82 | OpenFOAM Running, Solving & CFD | 1 | May 26, 2009 09:03 |
what happens if y+ is too large or too small | Bo Jensen | Siemens | 12 | February 20, 2003 00:31 |
small size holes simulation | brian ko | Phoenics | 5 | October 22, 2001 13:53 |
