How to Contour plot for omega_z ??
Old   July 5, 2010, 05:42
Default How to Contour plot for omega_z ??
Snehal Janwe
snehal is on a distinguished road
Hello Everybody,
I am working on vortex shedding of a cylinder in cross flow.
I want to plot the contour plots of vorticity in z direction so that i can see the positive and negative vortices. So i used the utility vorticity in Openfoam to calculate the same. Now while plotting the contour plots the only thing available is magnitude of vorticity(magVorticity in Openfoam).Therefore I am not able to see the positive and negative vortices.
Please let me know how to plot the contour plots for vorticity in z direction.
Also for reference I have attached the countour plot of magVorticity.
Any help will be aprreciated.
Thank you very much.
snehal is offline   Reply With Quote
Old   January 16, 2011, 15:28
Tarak
Tarak is on a distinguished road
Hii Snehal,
The vorticity utility gives vorticityX,Y andZ directly. So i don't think you should have a problem anymore.
Tarak.
Tarak is offline   Reply With Quote
Old   November 26, 2012, 17:04
Zheyu Zhou
zzhou is on a distinguished road
Hi Snehal,
You can calculate the x, y, z components of vorticity by "foamCalc components vorticity". Then you'll be able to see vorticityx, vorticityy and vorticityz in ParaView.
Cheers!
ZZ
zzhou is offline   Reply With Quote
Old   March 11, 2017, 05:41
Default vorticity problem
Fatemeh
fatemehfarshi62 is on a distinguished road
I have the same problem
Do you mean that one should type "foamCalc..." in terminal?
Thanks a lot
fatemehfarshi62 is offline   Reply With Quote
[OpenFOAM] basic question contour plot in paraview Kate ParaView 7 July 23, 2020 14:05
contour plot help jesse@uconn FLUENT 0 February 15, 2010 19:05
to plot Mach contour using GNUPLOT killtimm Main CFD Forum 2 December 28, 2009 11:15
How to plot vel vector & contour on same plane? student CFX 7 May 12, 2006 08:15
contour plot of stream function liu FLUENT 6 August 19, 2003 22:30
