create the file *.foam
While trying the OpenFOAMtutorial -Cavity , every time when I execute create blockmesh, Foam-1.5 do not create any file name cavity.foam although it give successful create mesh. I had try many time in different machine but still no cavity.foam file create.
Please help! Thank you in advance. C:\cfd\OpenFOAM-1.5\$FOAM_RUN\tutorials\icoFoam\cavity>blockmesh Exec : blockmesh Date : Jul 03 2010 Time : 14:15:45 Host : hostname PID : 1720 Case : C:\cfd\OpenFOAM-1.5\$FOAM_RUN\tutorials\icoFoam\cavity nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 0 Number of boundary faces : 6 Number of defined boundary faces : 6 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Writing polyMesh end C:\cfd\OpenFOAM-1.5\$FOAM_RUN\tutorials\icoFoam\cavity>parafoam 'parafoam' is not recognized as an internal or external command, operable program or batch file. C:\cfd\OpenFOAM-1.5\$FOAM_RUN\tutorials\icoFoam\cavity>paraFoam 'paraFoam' is not recognized as an internal or external command, operable program or batch file. C:\cfd\OpenFOAM-1.5\$FOAM_RUN\tutorials\icoFoam\cavity>paraFoam -case 'paraFoam' is not recognized as an internal or external command, operable program or batch file. C:\cfd\OpenFOAM-1.5\$FOAM_RUN\tutorials\icoFoam\cavity>paraview Paraview open, but pipline Browser can’t find the cavity.foam. Please help me! Mr Phong |
Greetings Mr Phong and welcome to the forum!
You seem a bit lost... the OpenFOAM version you are using isn't the official version. Most likely, you are using the fork openfoam-mswin. And the problem you are having has already been addressed on this thread: http://www.cfd-online.com/Forums/ope...r-windows.html - see scroll down to the posts #10 and #11! Best regards, Bruno |
Thankyou Bruno!
I will refer it. I want to ask you a question? I don't know the function between OpenFoam for window and OpenFoam for linux is similar or not? If i use the Open Foam for window i can use full function like OpenFoam for linux. Best regards, Phong |
Greetings Phong,
Well, openfoam-mswin has limited functionality. You can try using it until you reach its limitations. The official Linux version (available here: www.openfoam.com) has the full set of available solvers and utilities. For a quick start with the Linux version, you'll be better off with the Ubuntu 10.04 version: http://www.openfoam.com/download/ubuntu.php There is another variant of OpenFOAM, named OpenFOAM-dev, that has additional functionalities on top of the official version, available here: http://sourceforge.net/projects/openfoam-extend/files/ It even has a sweet DVD image that has that version pre-installed and ready to use! In case you are interested in full OpenFOAM capabilities in Windows and don't have time to loose, you can also resort to low cost paid solutions available by:
Thanks a lot for helping me, Bruno
I doawnload kubuntu from address: http://sourceforge.net/projects/openfoam-extend/files/ When I instal it, i received a noted ------------ Kubuntu installer An error occurred Cannot download the matalink and therefore the ISO For more information, please see the log file C:\document1\...\wubi-10.04-rev189.log ----------- I had opened file wubi-10.04-rev189.log, …. 07-07 12:00 DEBUG CommonBackend: Searching for local CD 07-07 12:00 DEBUG Distro: checking whether C:\DOCUME~1\THANHP~1\LOCALS~1\Temp\pyl23A.tmp is a valid Kubuntu CD 07-07 12:00 DEBUG Distro: does not contain C:\DOCUME~1\THANHP~1\LOCALS~1\Temp\pyl23A.tmp\casp er\filesystem.squashfs 07-07 12:00 DEBUG Distro: checking whether D:\ is a valid Kubuntu CD 07-07 12:00 DEBUG Distro: does not contain D:\casper\filesystem.squashfs 07-07 12:00 DEBUG Distro: checking whether E:\ is a valid Kubuntu CD 07-07 12:00 DEBUG Distro: does not contain E:\casper\filesystem.squashfs 07-07 12:00 DEBUG Distro: checking whether F:\ is a valid Kubuntu CD 07-07 12:00 DEBUG Distro: does not contain F:\casper\filesystem.squashfs 07-07 12:00 DEBUG Distro: checking whether Z:\ is a valid Kubuntu CD 07-07 12:00 DEBUG Distro: does not contain Z:\casper\filesystem.squashfs 07-07 12:00 DEBUG CommonBackend: Searching for local ISO 07-07 12:00 DEBUG CommonBackend: Could not find any ISO or CD, downloading one now 07-07 12:00 DEBUG TaskList: New task get_metalink 07-07 12:00 DEBUG TaskList: ### Running get_metalink... 07-07 12:00 DEBUG downloader: downloading http://releases.ubuntu.com/kubuntu/1...amd64.metalink > E:\ubuntu\install 07-07 12:00 ERROR CommonBackend: Cannot download metalink file http://releases.ubuntu.com/kubuntu/1...amd64.metalink err=[Errno 4] IOError: <urlopen error (10060, 'Operation timed out')> 07-07 12:00 DEBUG downloader: downloading http://cdimage.ubuntu.com/kubuntu/da...amd64.metalink > E:\ubuntu\install 07-07 12:00 ERROR CommonBackend: Cannot download metalink file2 http://cdimage.ubuntu.com/kubuntu/da...amd64.metalink err=[Errno 4] IOError: <urlopen error (10060, 'Operation timed out')> 07-07 12:00 DEBUG TaskList: ### Finished get_metalink 07-07 12:00 ERROR TaskList: Cannot download the metalink and therefore the ISO Traceback (most recent call last): File "\lib\wubi\backends\common\tasklist.py", line 197, in __call__ File "\lib\wubi\backends\common\backend.py", line 493, in get_iso File "\lib\wubi\backends\common\backend.py", line 331, in download_iso Exception: Cannot download the metalink and therefore the ISO 07-07 12:00 DEBUG TaskList: # Cancelling tasklist 07-07 12:00 DEBUG TaskList: # Finished tasklist 07-07 12:00 ERROR root: Cannot download the metalink and therefore the ISO Traceback (most recent call last): File "\lib\wubi\application.py", line 56, in run File "\lib\wubi\application.py", line 130, in select_task File "\lib\wubi\application.py", line 156, in run_installer File "\lib\wubi\backends\common\tasklist.py", line 197, in __call__ File "\lib\wubi\backends\common\backend.py", line 493, in get_iso File "\lib\wubi\backends\common\backend.py", line 331, in download_iso Exception: Cannot download the metalink and therefore the ISO I cannot know how to do, please help me. I ‘m student, I want to study OpenFoam to simulation the fluid mechanics in my graduate theme (I don’t have a lot of time) Please help me! Best Regards. Phong |
Greetings Phong,
I'm sorry, I should have posted the link to the thread that explains on how to use the Kubuntu DVD: http://www.cfd-online.com/Forums/ope...d-kubuntu.html And if after following the steps on that thread you still get problems using it, please use that thread for asking how to use it, because they know the DVD much better than me! Best regards and good luck! Bruno |
Kubuntu OpenFOAM
Dear Bruno
this is two case which i had run OpenFOAM 1) OpenFoam for win - when i ran IcoFoam in cavity case it created 5 folder: 0.1, 0.2, 0.3, 0.4, 0.5. [IMG]file:///C:/DOCUME%7E1/THANHP%7E1/LOCALS%7E1/Temp/msohtml1/01/clip_image002.jpg[/IMG] Time = 0.5 Courant Number mean: 0.116925 max: 0.852134 DILUPBiCG: Solving for Ux, Initial residual = 1.89493e-007, Final residual = 1. 89493e-007, No Iterations 0 DILUPBiCG: Solving for Uy, Initial residual = 4.14522e-007, Final residual = 4. 14522e-007, No Iterations 0 DICPCG: Solving for p, Initial residual = 1.06665e-006, Final residual = 3.3960 4e-007, No Iterations 1 time step continuity errors : sum local = 5.25344e-009, global = 8.60268e-020, c umulative = -1.20491e-018 DICPCG: Solving for p, Initial residual = 5.36118e-007, Final residual = 5.3611 8e-007, No Iterations 0 time step continuity errors : sum local = 6.86432e-009, global = -1.44128e-018, cumulative = -2.64619e-018 ExecutionTime = 1.11 s ClockTime = 1 s End C:\Program Files\cfd\OpenFOAM-1.5\tutorials\icoFoam\cavity> but i ran paraFoam it show: C:\Program Files\cfd\OpenFOAM-1.5\tutorials\icoFoam\cavity>paraFoam 'paraFoam' is not recognized as an internal or external command, operable program or batch file. I couldn'n run FaraFOAM. Why? I just ran paraview (ParaView 3.4.0.mitch) to show all picture in the cavity case. 2) Kubuntu OpenFOAM (http://sourceforge.net/projects/open...nFOAM_kubuntu/) i ran icoFoam, but i didn'n see 5 folder ( 0.1, 0.2, 0.3, 0.4 0.5). [IMG]file:///C:/DOCUME%7E1/THANHP%7E1/LOCALS%7E1/Temp/msohtml1/01/clip_image002.jpg[/IMG] I ran IcoFoam, it show: phong@phong-dell:~/OpenFOAM/phong-1.5-dev/run/tutorials/incompressible/icoFoam/cavity$ icoFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5-dev | | \\ / A nd | Revision: exported | | \\/ M anipulation | Web: http://www.OpenFOAM.org | \*---------------------------------------------------------------------------*/ Exec : icoFoam Date : Jul 22 2010 Time : 15:15:33 Host : phong-dell PID : 2092 Case : /home/phong/OpenFOAM/phong-1.5-dev/run/tutorials/incompressible/icoFoam/cavity nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0 max: 0 velocity magnitude: 0 Attempt to return dictionary entry as a primitive file: /home/phong/OpenFOAM/phong-1.5-dev/run/tutorials/incompressible/icoFoam/cavity/system/fvSolution::U from line 30 to line 33. From function ITstream& primitiveEntry::stream() const in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 83. FOAM aborting Aborted i couldn't show all picture in the cavity case. Please help me! i want to study both of case ( in window and Kubuntu OpenFoam) Thanh you very much. Best Regards Phong |
Kubuntu OpenFOAM
Dear Bruno
Greetings Phong,
As for Windows, it seems that you are using the openfoam-mswin project... anyway, start reading from this post: http://www.cfd-online.com/Forums/ope...tml#post234151 - post #10 As for KUbuntu+OpenFOAM-dev, I have no clue as to what is going wrong :( Like I've said before, I haven't used it yet. Possibly you didn't run blockMesh prior to icoFoam. And also like I said before, you better ask on thread for the KUbuntu DVD: http://www.cfd-online.com/Forums/ope...d-kubuntu.html Best regards, Bruno |
Thank you very much Bruno.
I will ask someone in the thread for the KUbuntu DVD: http://www.cfd-online.com/Forums/ope...d-kubuntu.html Best Regards. Phong |
Please help me!
Dear Bruno
I did it as your advice but up to now nobody help me! http://www.cfd-online.com/Forums/openfoam-installation/76345-openfoam-dev-live-usb-dvd-based-kubuntu.html#post268848 Please help me to solve this problem. Thank you very much. I wait good new from you Best regards Phong |
Greetings Phong,
I've just tested the Live KUbuntu DVD with OpenFOAM-dev and I had no issues. Then I re-read the output you posted and then it hit me: Quote:
