-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Problem compiling OpenFoamTurbo (http://www.cfd-online.com/Forums/openfoam/77969-problem-compiling-openfoamturbo.html)
troy July 8, 2010 13:35
I'm having a horrible time trying to compliling OpenFoamTurbo. I have followed the directions on http://openfoamwiki.net/index.php/Si..._OpenFoamTurbo to no avail. It first complained about the parts of the Make files that had lines that had been tried to be commented out that it was trying to read. I deleted all those lines (they had to do with rotating pressure, split velocity, and temperature) to get the basic rotating reference frame module, and it still won't compile. Now it says
finiteVolume/cfdTools/general/SRFZones/SRFZone.C: In member function ‘void Foam::SRFZone::addCoriolis(Foam::fvVectorMatrix&) const’:
finiteVolume/cfdTools/general/SRFZones/SRFZone.C:97: error: request for member ‘db’ is ambiguous
/home/tmiller/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude/IOobject.H:235: error: candidates are: const Foam::objectRegistry& Foam::IOobject::db() const
I thought it might be having trouble finding all the #include files. Could that be the issue?
Troy
hani July 11, 2010 13:08
Hi Troy,
It seems like you are using OpenFOAM-1.7.0. Is that so?
In the instructions of OpenFOAM Turbo, you can see that versions 1.4.1 and 1.5 are mentioned. I'm quite sure that some modifications are necessary for it to work with 1.7.0.
Håkan
troy July 12, 2010 10:08
Yes, I'm attempting to use OpenFOAM-1.7.0. Thank you for your insight about using the Turbo 1.5 level. I'm giving up for now. I need to to do 3D-high speed turbo work with imported geometries, and that seems to be above the level of where OpenFOAM has been developed to this point. If I were more of a CFD and coding guru, I might jump at the challenge, but it is too overwhelming for the amount of time I have to do this.
