3D axissymmetric problem
Old   July 2, 2010, 08:12
Default 3D axissymmetric problem
noramat is on a distinguished road
hello,
i have to solve a axis-symmetric 3D-problem (cylinder) - magnetohydrodynamic problem coupled with boussinesq-approximation. Is there any way to solve it in OpenFoam without cylindrical coordinates and without the wedge condition, only with a special boundary condition!? So - maybe - through a constant azimuthal (theta direction) component!? But how could i implement such a condition?
Thanks a lot.
noramat
noramat is offline   Reply With Quote
Old   July 2, 2010, 08:30
marcbest is on a distinguished road
i'm also a starter at OF and i'm not familiar with magnetohydrodynamics in OF but generally 2D Simulations can be done with wedges
if you want to define a new boundary condition you have to programm and compile it, have a look at:
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2007/
http://www.tfd.chalmers.se/~hani/kur...yCondition.pdf
Implement boundary condition
i hope this helps
marcbest is offline   Reply With Quote
Old   July 2, 2010, 08:45
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Originally Posted by noramat View Post
i have to solve a axis-symmetric 3D-problem (cylinder) ... Is there any way to solve it in OpenFoam without cylindrical coordinates and without the wedge condition, only with a special boundary condition!?
If your case is 3D, you should use a cyclic bc and not a wedge, which applies only on 2D problems (one cell thick). If you apply cyclic, it is not necessary to convert everything in cylindrical coordinates, but cartesian will be ok.
Hope this helps.
cheers,
mad
maddalena is offline   Reply With Quote
Old   July 13, 2010, 17:07
thanks for your answers!
now i have another question to wedge-type ..
so - wedge-type is used for 2d-axisymmetric problems. Does the wedge-type imply, that all quantities are independent of the angular/azimuthal component phi (constant in phi direction) and that the angular/azimuthal velocity u_phi is zero?
If the last fact is not true (u_phi = 0), how could i implement that? Maybe through a special boundary condition again?
thanks a lot again!
noramat
Old   July 13, 2010, 17:43
maddalena's Avatar
maddalena
Hi Noramat,
I am not sure I understand your question correctly but... Wedge type is 2D. OF does the trick of using a 3D mesh to solve a 2D case, but in reality all your properties are (and remain) constant along the third dimension, which is not solved indeed. Thus I would say yes:
hope that helps
mad
Old   July 14, 2010, 06:22
thanks again!
that's one answer i need
but now i'm still not sure because of the other fact.. so i have to solve a axisymmetric problem (zylinder) with the condition that the angular velocity u_phi is zero. but is it realised by wedge-type?
thanks!
normat
Old   July 14, 2010, 06:53
maddalena's Avatar
maddalena
Hi Noramat,
is U_phi the angular velocity? If it is, than u_phi will be zero, since the angular direction is not solved by OF. On the other hand, if you are interested on an angular direction, than your problem is not 2D. Indeed, you have two geometrical directions (radial and axial) + one phisical direction (circonferential, or angular, as you like), thus the problem is 3D. In that case, the wedge bc cannot be applied and you should use a cyclic instead.
hope that this makes things clearer.
cheers,
mad
Old   July 14, 2010, 06:58
thanks very much!
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 11:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
