Peclet number does not appear in ParaView
Old   July 9, 2010, 03:52
Default Peclet number does not appear in ParaView
Claus Meister
idrama is on a distinguished road
Hello Foamers!
I ran an icoFoam case and afterwards the Pe tool. I wanted to visualize Pe in ParaView I notice that I have no access to fields. I would like to see them, what do I do?
Cheers in advance
idrama is offline   Reply With Quote
Old   July 9, 2010, 06:09
marcbest is on a distinguished road
hi claus,
i think you can only see Pe as Vector arrows. To do this you have to type
foamToVTK -surfaceFields
then start paraview and open VTK/surcfaceFields, then "Apply" and Filters/Common/Glyph or simply click the "Glyph" button, after this you can see the vectors of Pe...
i hope this helps
marcbest is offline   Reply With Quote
Old   July 9, 2010, 07:27
Claus Meister
Hello marcbest,
thanks for you advice which had worked, but this way is unsatisfactory, because such an effort must be made. I keep looking for an better solution; probaly the code has to be rewritten.
Cheers
Old   July 9, 2010, 12:51
Nima Samkhaniani
nimasam is on a distinguished road
Hi
why don't you try to add peclet number in creatFields.H? as a variable which it shouldn't be read but it should be write ????
nimasam is offline   Reply With Quote
Old   July 10, 2010, 04:17
Claus Meister
what you mean by that? Do you mean to cope the problem by using volScalarField? Currently, I am trying either, but the problem is: I do not know how to compute the measure of the cells, i.e.
Let U, nu and nut be given then
volScalarField Pe
IOobject
"Pe",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mag(U)/(nu+nut)*"What"
What can I insert for "What"?
Cheers
Old   July 10, 2010, 04:20
Claus Meister
Additionally, I should mention that I am only interesting in Navier-Stokes convection-dominated flows.
Old   July 10, 2010, 07:17
Nima Samkhaniani
hi friend
one way can be to enter characteristic length, through Dic by "readScalar" function
then put this length instead of "what" but im not sure!!!
Old   September 15, 2010, 11:56
alf12 is on a distinguished road
You may have a look at the Co utility, it outputs a volScalarField from a surfaceScarlarField. This could be adapted to the Pe utility
alf12 is offline   Reply With Quote
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
