LES-kOmegaSSTSAS
Old   July 9, 2010, 08:40
Default LES-kOmegaSSTSAS
Rasoul
aut_iut is on a distinguished road
Dear Foamer,
My case is a basic case related to turbulent flow over a cylinder. In fact I am going to compare lift&Drag coeffs with the literature data. I succeeded to use RAS-kOmegaSST already.
But my results were not accurate enough. Since the accuracy of LES models are better than RAS, I tried to use LES-kOmegaSSTSAS turbulence model for my case. After running, the execution process crashed with the following errors.
I think these errors are because of initial values for the turbulence model or used solvers. Am I right? Any body has an idea for the initial values of the nuSgs? I also changed the timeStep, but this has no effect.
Time = 0.008
Courant Number mean: 0.00534794 max: 0.0800331
DILUPBiCG: Solving for Ux, Initial residual = 0.0314821, Final residual = 2.40782e-07, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.00938822, Final residual = 1.69819e-07, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.0736961, Final residual = 3.42136e-07, No Iterations 1
GAMG: Solving for p, Initial residual = 0.429489, Final residual = 0.0295009, No Iterations 3
time step continuity errors : sum local = 9.5465e-08, global = -7.2069e-10, cumulative = -2.89625e-09
GAMG: Solving for p, Initial residual = 0.112661, Final residual = 1.77703e+31, No Iterations 1000
time step continuity errors : sum local = 4.46134e+25, global = 1.33676e+07, cumulative = 1.33676e+07
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 9.30655e+08, No Iterations 1001
bounding k, min: -10819.8 max: 8259.16 average: -4.75152
DILUPBiCG: Solving for omega, Initial residual = 1, Final residual = 63348.9, No Iterations 1001
bounding omega, min: -5.33351e+37 max: 2.06354e+44 average: 2.12765e+40
ExecutionTime = 21.42 s ClockTime = 24 s
Time = 0.01
Courant Number mean: 4.0992e+26 max: 2.81609e+27
DILUPBiCG: Solving for Ux, Initial residual = 0.765954, Final residual = 1.00338, No Iterations 1001
DILUPBiCG: Solving for Uy, Initial residual = 0.910766, Final residual = 118092, No Iterations 1001
DILUPBiCG: Solving for Uz, Initial residual = 0.999613, Final residual = 1.01149, No Iterations 1001
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/home/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/home/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libOpenFOAM.so"
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/OpenFOAM/OpenFOAM-1.6.x/lib/linuxGccDPOpt/libfiniteVolume.so"
in "/home/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linuxGccDPOpt/pisoFoam"
#9 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Floating point exception
Best regards,
Rasoul
aut_iut is offline   Reply With Quote
Old   July 9, 2010, 09:36
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Why not use nut from SST result as initial guess for SAS. Actually It is SST based SAS which is not the tranditional LES method
waynezw0618 is offline   Reply With Quote
Old   July 9, 2010, 10:31
Rasoul
Dear wayne,
Thank you for your fast reply. But, It's impossible to use nut from RAS-kOmegaSST for LES-kOmegaSSTSAS. Because in the latter model there is no nutwallFunction and we have to use nuSgs instead of nut. Anyway I tried your suggestion and faced with the following error:
--> FOAM FATAL ERROR:
request for RASModel RASProperties from objectRegistry region0 failed
available objects of type RASModel are
0
Any other suggestion?
Old   July 9, 2010, 11:50
wayne.zhang
you could modify the boundary type in file of k and omega
it is problem of wall function
http://www.cfd-online.com/Forums/ope...roperties.html
LES kOmegaSSTSAS / looking for RASProperties podallaire OpenFOAM Bugs 24 November 3, 2020 15:18
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 09:58
