Home > Forums > OpenFOAM
Variables inside classes
Old   July 12, 2010, 11:30
Default Variables inside classes
Tony
tonyuprm is on a distinguished road
Hi all,
I'm creating a class but I cannot declare variables inside my class to then use them in my member functions. Here is the error I get.
const scalar pi2=3.14;
error: ISO C++ forbids initialization of member ‚pi2‚
error: making ‚pi2‚ static
tonyuprm is offline   Reply With Quote
Old   July 13, 2010, 02:27
Mark Olesen
olesen will become famous soon enough
Originally Posted by tonyuprm View Post
Hi all,
Like the error message says, you'll need to make the data member static, which means it is the same for every instance.
static const scalar pi2 = 3.14;
Note that in-header initialization only works for simple types, for more complex types you need to initialize them in the .C file.
BTW: if you really just need PI, you could also consider using the constants provided with OpenFOAM:
http://foam.sourceforge.net/doc/Doxy...stants_8H.html
olesen is offline   Reply With Quote
Old   July 13, 2010, 13:16
Tony
That worked just fine. Thanks!
Thread Tools
Trackbacks are On
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Modelling the Heat flow inside the curing oven Marios Vlad CFX 1 February 6, 2008 08:11
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
