July 15, 2010, 18:09 |
Definitions for Initial and Final Residuals
Patrick
Rep Power: 16 |
Dear FOAMers
I am trying to learn the importance of initial and final residuals. Is there any place where I can get their definitions? I am learning to use simpleFoam to solve simple problems like internal flow over through a pipe with sudden expansion. For low Re (~300) both the initial and final residuals drop to 1e-6. But when I triple the Re (~1000), the initial residual stay at ~0.002 range while the final residual drops to 1e-7. Irrespective of the problem, If I want to say the solution is converged, how low should the initial residuals go? Thanks |
July 16, 2010, 03:55 |
Rep Power: 15 |
hi patrick,
the initial residuals are the important ones, by default the residuals must be lower than 10^-5 that the simulation is converged. The final residuals are the residuals in the current step after n-iterations -> No Iterations n with pyFoamPlotWatcher you can visualise the initial residuals. http://openfoamwiki.net/index.php/Contrib_PyFoam regards |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 03:32 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
