July 14, 2010, 07:03 |
buoyantPisoFam error
Hello Foamers,
I try to run a LES case with buoyantPisoFoam but whatever I do it always returns me this error : ************************************************** ************************************************** * Create time Create mesh for time = 0 Reading g Reading thermophysical properties Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type LESModel Selecting LES turbulence model oneEqEddy oneEqEddyCoeffs { ce 1.048; Prt 1; ck 0.094; } Creating field DpDt #0 Foam::error:: printStack(Foam::Ostream&) in "/home/norbertb/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/norbertb/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/norbertb/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/home/norbertb/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/buoyantPisoFoam" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam:: operator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/home/norbertb/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/buoyantPisoFoam" #6 main in "/home/norbertb/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/buoyantPisoFoam" #7 __libc_start_main in "/lib/i686/cmov/libc.so.6" #8 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122 Floating point exception ************************************************** ************************************************** * Since there is no issue with RANS tutos, I suppose it is caused by LES, but I do not know where exactly. Any help would be greatly appreciated |
July 16, 2010, 04:36 |
It seems that error happens at this level, in the createFields.h file :
Info<< "Creating field DpDt\n" << endl; volScalarField DpDt ( "DpDt", fvc:: DpDt(surfaceScalarField("phiU", phi/fvc::interpolate(rho)), p) ); But I still don't understand how to avoid it ... Does anyone got the same issue / an idea ? |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
[Netgen] Compiling Netgen on Fedora Core is driving me crazy | jango | OpenFOAM Meshing & Mesh Conversion | 3 | November 9, 2007 13:29 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
