-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   thermal conductivity --> anisotropic material (http://www.cfd-online.com/Forums/openfoam/78194-thermal-conductivity-anisotropic-material.html)
val46 July 15, 2010 01:52
i have a thermal conduction problem.
I need to modell a cylinder with different conductivity values in x,y and z direction. The cylinder is within a metal tube (isotropic material ;))
I think i can simply create 3 variables in transportproperties. Let's say lambdaX, lambdaY and lambdaZ. But after that i haven't a glue what to do next. (I'm pretty new to OpenFoam).
Thanks in advance.
Toni
benk July 19, 2010 09:12
You just need to make a volTensorField for your thermal conductivities. In your time=0 directory, create your conductivity field using something like:
FoamFile
    version    2.0;
    format      ascii;
    class      volTensorField;
    object      Ds;
dimensions      [0 2 -1 0 0 0 0];
internalField  uniform (xx 0 0 0 yy 0 0 0 zz);
boundaryField
where xx yy and zz are the values in the 3 different directions.
val46 July 20, 2010 05:26
thanks for your reply.
How will the solver recognize the new file?
Don't i have to modify the solver for that?
benk July 20, 2010 08:19
You'll have to add the field by:
volTensorField lambda
IOobject
"lambda",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Or you could also just make a tensor in your transportProperties file and read it into your solver using
dimensionedTensor lambda(transportProperties.lookup("lambda"));
