Conditional Operation on a Geometric Field
Old   July 15, 2010, 16:52
Default Conditional Operation on a Geometric Field
Sachin Shanbhag
shane5ul is on a distinguished road
This may be a relatively simple question. I am simplifying the actual problem, for clarity.
Say variable X is of type volScalarField, and takes values between 0 and 1.0. I want to define a dependent variable Y (type volScalarField) whose definition depends on the local value of X. Something like
if(X>0.5) {
Y = exp(-X);
else {
Y = 2*X;
I tried to do this literally, and it said something like
error: no match for 'operator>' in 'Foam:perator*(const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::scalar&) [...]
shane5ul is offline   Reply With Quote
Old   July 15, 2010, 17:55
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Because this operation has to be done cell by cell, you need to use something like:
forAll (X, celli)
if(X[celli]>0.5) {
Y[celli] = exp(-X[celli]);}
else {
Y[celli] = 2*X[celli];}
If the field has dimensions, then you're going to have to make sure you deal with them properly, but other than that I think that's how it goes down.
mturcios777 is offline   Reply With Quote
Old   July 16, 2010, 12:02
Sachin Shanbhag
Thanks mturcios.
conditional, field
Perfoming operation if field is present sega OpenFOAM Programming & Development 13 August 16, 2023 05:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Operation to READ_IF_PRESENT field sega OpenFOAM Programming & Development 6 February 15, 2011 09:57
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
