buoyantPisoFoam vs buoyantBoussinesqPisoFoam
Old   July 26, 2010, 05:52
Question buoyantPisoFoam vs buoyantBoussinesqPisoFoam
NorbertB is on a distinguished road
Hi Foamers !
I am trying to study a turbulent flow in a duct, and more precisely the heat transfer on the walls of this duct.
I used buoyantPisoFoam, with the following LESProperties :
LESModel oneEqEddy;
delta vanDriest;
printCoeffs on;
turbulence on;
But I have just seen on the wiki that buoyantBoussinesqPisoFoam makes a specific assumption for turbulent SGS model.
So my question is : are my simulations relevant, or may I use buoyantBoussinesqPisoFoam ?
Thank you in advance for your comments/ideas.
NorbertB is offline   Reply With Quote
Old   July 30, 2010, 05:59
MSarkar
msarkar is on a distinguished road
buoyantPisoFoam is a transient solver for compressible fluid and buoyantBoussinesqPisoFoam is a transient solver for incompressible fluid where density variation is approximated using Boussinesq assumption. Applicable solver depends on the problem. If temperature variation is not much and you want to use incompressible flow simulation, you should use buoyantBoussinesqPisoFoam. If your problem is steady-state in nature, you can use buoyantBoussinesqSimpleFoam/buoyantSimpleFoam. I think there is particular reason to use LES turbulence model instead RAS model.
Hope this will help you.
Regards
M. Sarkar
msarkar is offline   Reply With Quote
Old   July 30, 2010, 08:11
Thank you very much for those explanations, I feel more confident in buoyantPisoFoam now ^^
Regards
Implementing Radiation Model into buoyantBoussinesqPisoFoam compiling error Fabian OpenFOAM Programming & Development 6 October 26, 2010 16:46
buoyantPisoFoam - engrid Boundary Layers pizzaice OpenFOAM 0 June 16, 2010 12:09
Error in solver? (buoyantPisoFoam) fijinx OpenFOAM Running, Solving & CFD 7 February 2, 2010 14:58
