July 27, 2010, 08:03 |
paraFoam crash
after starting paraFoam I get following error message: ***:~/OpenFOAM/***-1.6/run/Vak200$ paraFoam created temporary 'Vak200.OpenFOAM' fileName::stripInvalid() called for invalid fileName H2(Kopie)~ For debug level (= 2) > 1 this is considered fatal Aborted I appreciate any hints! Thanks |
July 27, 2010, 19:45 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings FabOr,
The message seems self explanatory, but I'll break it down for you: Quote:
H2(Kopie)~ - this name seems to have one too many invalid characters! If I'm not mistaken, the tilde '~' is a bad one, and the parenthesis '()' might be two other characters that aren't acceptable. My guess is that you copied the file in the same folder as a backup - H2(Kopie) - but your text editor also created another backup of your backup - H2(Kopie)~. Sooo... the moral of this error: keep the contents of the time folders sanitized Best regards, Bruno
August 3, 2010, 05:00 |
Hi wyldckat,
thanks for your answer. Unfortunately i donīt have any copied files in my time directories. To be sure that it is not a problem connected to the file names,i have renamed all the H2-files to H2. but i get the same error message again... maybe it is important that i use chemkin and reactingFoam!? best regards, FabOr |
October 20, 2010, 22:42 |
was a solution found?
#4 | |
Hi FabOr,
Wonder if a solution to this error was found? I have the exact problem for a case i ran and want to view in paraFoam. Thank you for any insight, Lori Quote:
October 21, 2010, 04:43 |
Hi Lori,
wyldckat was right. iīve found files which were invalid named, but they were invisible. youīve got to type " strg+h " to see the invisible files, then you have to delete the invalid ones. hope that helps. best regards |
[OpenFOAM] pointVectorField in ParaFoam | s_braendli | ParaView | 0 | April 22, 2010 09:36 |
[OpenFOAM] Segmentation fault with paraFoam and paraview 3.6.1 on Fedora 11 32 and 64 bit | nanes | ParaView | 2 | September 11, 2009 10:12 |
[OpenFOAM] Parafoam basic questions | qtian | ParaView | 0 | July 20, 2007 12:52 |
[OpenFOAM] ParaFoam OF 14 decomposed cases | philippose | ParaView | 4 | April 18, 2007 06:17 |
[OpenFOAM] Both paraview and paraFoam crash on Redhat Linux WS v4 64bit | sek | ParaView | 4 | August 17, 2006 17:26 |
