interDyMFoam: "Only call if constructed with history capability"
Hello Foamers!
Proberly someone has already face that problem: time step continuity errors : sum local = 0.000205382, global = -0.000205382, cumulative = -0.000205382 GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 6.89706e-11, No Iterations 59 GAMGPCG: Solving for pcorr, Initial residual = 1.68619e-12, Final residual = 1.68619e-12, No Iterations 0 GAMGPCG: Solving for pcorr, Initial residual = 1.68619e-12, Final residual = 1.68619e-12, No Iterations 0 time step continuity errors : sum local = 1.47693e-14, global = 4.3336e-16, cumulative = -0.000205382 Courant Number mean: 0.00105231 max: 6.50462 Starting time loop Interface Courant Number mean: 0 max: 0 Courant Number mean: 7.51653e-05 max: 0.464615 deltaT = 7.14286e-05 Time = 7.14286e-05 Selected 0 cells for refinement out of 63328. --> FOAM FATAL ERROR: Only call if constructed with history capability From function hexRef8::getSplitPoints() in file polyTopoChange/polyTopoChange/hexRef8.C at line 4884. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/home/idrama/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/idrama/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::hexRef8::getSplitPoints() const in "/home/idrama/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libdynamicMesh.so" #3 Foam::dynamicRefineFvMesh::selectUnrefinePoints(do uble, Foam::PackedList<1u> const&, Foam::Field<double> const&) const in "/home/idrama/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libdynamicFvMesh.so" #4 Foam::dynamicRefineFvMesh::update() in "/home/idrama/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libdynamicFvMesh.so" #5 main in "/home/idrama/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/interDyMFoam" #6 __libc_start_main in "/lib64/libc.so.6" #7 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 Aborted I generated a mesh with snappyHexMesh with hexaedra only. However, when I want to let interDyMRun this error occurs. What is that suppose to mean, what can I do to fixed it? Cheers |
I used to have the same problem. After the snappyHexMesh was created, I tried to use interDymFoam and got: --> FOAM FATAL ERROR: Only call if constructed with history capability From function hexRef8::getSplitPoints() in file polyTopoChange/polyTopoChange/hexRef8.C at line ....... So, I realise that deleting the "refinementHistory" file, it works! At least for me. I hope it helps... |
Dear all,
I am having exactly the same problem. I am working with buoyantBoussinesqPimpleFoam with Dynamic Meshing. I have added a few lines to the Solver and the solver seem to compile properly. But when I run my test case. I have the following error. SnappyHexMesh works fine. --> FOAM FATAL ERROR: Only call if constructed with history capability From function hexRef8::getSplitPoints() in file polyTopoChange/polyTopoChange/hexRef8.C at line 4890. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 Foam::hexRef8::getSplitPoints() const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #3 Foam::dynamicRefineFvMesh::selectUnrefinePoints(do uble, Foam::PackedBoolList const&, Foam::Field<double> const&) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" #4 Foam::dynamicRefineFvMesh::update() in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libdynamicFvMesh.so" #5 in "/home/atmoun/OpenFOAM/atmoun-2.0.1/platforms/linux64GccDPOpt/bin/buoyantBoussinesqPimpleDyMFoam_Unni" #6 __libc_start_main in "/lib/libc.so.6" #7 in "/home/atmoun/OpenFOAM/atmoun-2.0.1/platforms/linux64GccDPOpt/bin/buoyantBoussinesqPimpleDyMFoam_Unni" ./Allrun_Mesh_check: line 30: 19789 Aborted buoyantBoussinesqPimpleDyMFoam_Unni > buoyantBoussinesqPimpleDyMFoam_Unni Thanks & Regards Unnikrishnan. |
thanks for your very valuable hint! Tiny side remark: the file is located at the directory Code:
onstant/polyMesh/ Regards, Peter |
