deji |
August 4, 2010 02:33 |
Code To Compute Nusselt # on wall
Hey there Foamers. I am writing a post-processor to compute the mean Nusselt number on a wall in a turbulent flow (LES). I am getting the following error:
wallHeatRates.C: In function ‘int main(int, char**)’:
wallHeatRates.C:99: error: ‘obr_’ was not declared in this scope
wallHeatRates.C:99: error: expected primary-expression before ‘>’ token
make: *** [Make/linuxGccDPOpt/wallHeatRates.o] Error 1
Here is my code wallHeatRates.C
#include "fvCFD.H" //adds file prior to compiling source
#include "makeGraph.H"
#include <cmath>
#include "LESModel.H"
#include "wallHeatRates.H"
#include "volFields.H"
namespace Foam
defineTypeNameAndDebug(wallHeatRates,0);
// addNamedToRunTimeSelectionTable(wallHeatRates);
//**************Constructor definition*********//
Foam::wallHeatRates::wallHeatRates
const objectRegistry& obr
: obr_(obr)
Foam::wallHeatRates::~wallHeatRates() //Destructor
// int main(int argc, char *argv[])
int main(int argc, char **argv)
timeSelector::addOptions();
# include "setRootCase.H" //checks if run is scalar or parallel to distribute arguments accordingly
# include "createTime.H" //cpu,clock time stuff,access to constant dir.
instantList timeDirs = timeSelector::select0(runTime, args);
# include "createMesh.H" //required for mesh info.,interpolation,mesh stuff....
// const word& gFormat = runTime.graphFormat();
forAll(timeDirs, timeI)
runTime.setTime(timeDirs[timeI], timeI);
Info<< "Time = " << runTime.timeName() << endl;
IOobject TMeanheader
"TMean",
runTime.timeName(),
mesh,
IOobject::MUST_READ
// Check T exists
if (TMeanheader.headerOk())
mesh.readUpdate();
Info<< " Reading TMean Field" << endl;
volScalarField TMean(TMeanheader, mesh);
Info<< " Calculating wallGradTMean" << endl;
Info << "Reading LES Properties" << endl;
const Foam::compressible::LESModel & sgs = obr_.lookupObject<compressible::LESModel>("LESProperties");//<---
label patchK = mesh.boundaryMesh().findPatchID("wallHot"); //specifies the patch to compute dT/dn
const scalarField alphaEffw = sgs.alphaEff()().boundaryField()[patchK];
const scalarField alphaw = sgs.alpha().boundaryField()[patchK];
scalarField GradTw = TMean.boundaryField()[patchK].snGrad();
direction d_; //axis direction,
d_= Foam::point::Z;
const scalarField Xv = mesh.boundaryMesh()[patchK].faceCentres().component(d_);
label length = Xv.size();
for (label i=0;i<length;i++)
// makeGraph( Xv[i], magGradT[i],"dTdn",runTime.path(), gFormat );
// Info << "Height" << tab << Xv[i] << tab << "dTdn" << tab << GradTw[i] <<endl;
Info << "Spatially Average in Spanwise Direction" << endl;
scalarField Xv_tmp(Xv);
Foam::sort(Xv_tmp);
label nbVerticalPoint = 1;
scalarField Xv_mean(length);
Xv_mean[0] = Xv_tmp[0];
for(label i=1; i<length; i++)
if((Xv_tmp[i] - Xv_mean[nbVerticalPoint-1]) > 1e-6)
Xv_mean[nbVerticalPoint++] = Xv_tmp[i];
scalarField GradTwMean(nbVerticalPoint);
for(label j=0; j<nbVerticalPoint; j++)
GradTwMean[j] = 0.0;
for(label i=0; i<length; i++)
label index = -1;
for(label j = 0; j< nbVerticalPoint; j++)
//if(((Xv_tmp[i] - Xv_mean[j]) < 1e-6) || ((Xv_tmp[i] - Xv_mean[j]) > 1e-6))
if( mag(Xv_tmp[i] - Xv_mean[j]) < 1e-6 )
index= j ;
break;
GradTwMean[index] += GradTw[i];
for (label j= 0; j< nbVerticalPoint; j++)
GradTwMean[j] /= ceil(length/nbVerticalPoint);
// Info<<Xv_mean[j]<<tab<<GradTwMean[j]<<endl;
else
Info<< "No TMean" << endl;
Info<< "End" << endl;
return 0;
I do have a header file as well called wallHeatRates.H where I defined the wallHeatRates constructor. The error is pointing to this line that has
const Foam::compressible::LESModel & sgs = obr_.lookupObject<compressible::LESModel>("LESProp erties");
Can someone help me out here as I am just working my way up in OpenFOAM programming.
