2injections DieselFoam
Old   August 4, 2010, 02:47
Default 2injections DieselFoam
Rickard
Rickard.Solsjo is on a distinguished road
Hi, im trying to inject fuel with two different injectionpressures.
It looks something like this
injectorType commonRailInjector;
commonRailInjectorProps
position (0 0 0);
direction (0 0 -1);
diameter 110e-06;
mass 0.7e-06;
injectionPressure 115.0e+6;
temperature 1000;
nParcels 500;
X
1.0
massFlowRateProfile
(0.0000 0)
(0.0001 1.0)
(0.0002 0)
injectionPressureProfile
(0.0 1.0)
(0.0002 1.0)
position (0 0 0);
direction (0 0 -1);
diameter 110e-06;
mass 0.7e-06;
injectionPressure 200.0e+6;
temperature 1000;
nParcels 500;
X
1.0
massFlowRateProfile
(0.00300 0)
(0.00301 1.0)
(0.00302 0)
(0.00300 1.0)
(0.00302 1.0)
The problem is that nothing happens until the later injections. Any ideas?
Thx
Rickard.Solsjo is offline   Reply With Quote
Old   August 4, 2010, 07:01
Rickard
I got another problem too
[13] #0 Foam::error:rintStack(Foam::Ostream&) in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libOpenFOAM.so"
[13] #1 Foam::sigFpe::sigFpeHandler(int) in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libOpenFOAM.so"
[13] #2 __restore_rt at sigaction.c:0
[13] #3 pow.L in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64IccDPOpt/dieselFoam"
[13] #4 Foam::RanzMarshall::Nu(double, double) const in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so"
[13] #5 Foam::RanzMarshall::relaxationTime(double, double, double, double, double, double) const in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so"
[13] #6 Foam:arcel::setRelaxationTimes(int, double&, Foam::Field<double>&, double&, Foam::Field<double>&, Foam::spray const&, double, Foam::Vector<double> const&, double, double, Foam::Field<double> const&, Foam::Field<double> const&, double) in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so"
[13] #7 Foam:arcel::move(Foam::spray&) in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so"
[13] #8 Foam::spray::inject() in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so"
[13] #9 Foam::spray::evolve() in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so"
[13] #10 main in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64IccDPOpt/dieselFoam"
[13] #11 __libc_start_main in "/lib64/libc.so.6"
[13] #12 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64IccDPOpt/dieselFoam"
[mn150:11535] *** Process received signal ***
[mn150:11535] Signal: Floating point exception (8)
[mn150:11535] Signal code: (-6)
[mn150:11535] Failing at address: 0x8b400002d0f
[mn150:11535] [ 0] /lib64/libc.so.6 [0x39806302d0]
[mn150:11535] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x3980630265]
[mn150:11535] [ 2] /disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libOpenFOAM.so(_ZN4Foam6sigFpe13sigFpeHandlerEi+0x 3b) [0x2ba9524b02eb]
[mn150:11535] [ 3] /lib64/libc.so.6 [0x39806302d0]
[mn150:11535] [ 4] dieselFoam [0x4cf945]
[mn150:11535] [ 5] /disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so(_ZNK4Foam12RanzMarshall2NuEdd+0x 1d) [0x2ba94f39001d]
[mn150:11535] [ 6] /disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so(_ZNK4Foam12RanzMarshall14relaxat ionTimeEdddddd+0x36) [0x2ba94f390096]
[mn150:11535] [ 7] /disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so(_ZN4Foam6parcel18setRelaxationTi mesEiRdRNS_5FieldIdEES1_S4_RKNS_5sprayEdRKNS_6Vect orIdEEddRKS3_SD_d+0xafc) [0x2ba94f34f2fc]
[mn150:11535] [ 8] /disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so(_ZN4Foam6parcel4moveERNS_5sprayE +0x470) [0x2ba94f33abf0]
[mn150:11535] [ 9] /disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so(_ZN4Foam5spray6injectEv+0xd7c) [0x2ba94f35f43c]
[mn150:11535] [10] /disk/global/szrobi/OpenFOAM/OpenFOAM-1.6.x/lib/linux64IccDPOpt/libdieselSpray.so(_ZN4Foam5spray6evolveEv+0x847) [0x2ba94f357f47]
[mn150:11535] [11] dieselFoam [0x41abb5]
[mn150:11535] [12] /lib64/libc.so.6(__libc_start_main+0xf4) [0x398061d994]
[mn150:11535] [13] dieselFoam(_ZNK4Foam11regIOobject11writeObjectENS_ 8IOstream12streamFormatENS1_13versionNumberENS1_15 compressionTypeE+0xe9) [0x418ec9]
[mn150:11535] *** End of error message ***
[mn155.mpi][[24270,1],9][btl_tcp_frag.c:214:mca_btl_tcp_frag_recv] mca_btl_tcp_frag_recv: readv failed: Connection reset by peer (104)
[mn155.mpi][[24270,1],8][btl_tcp_frag.c:214:mca_btl_tcp_frag_recv] mca_btl_tcp_frag_recv: readv failed: Connection reset by peer (104)
mpirun noticed that process rank 13 with PID 11535 on node mn150.mpi exited on signal 8 (Floating point exception).
Does it have to do with the injection pressure?
injector model in dieselFoam leejc OpenFOAM 8 April 3, 2018 12:30
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 14:41
Running dieselFoam in parallel. Palminchi OpenFOAM 0 February 17, 2010 04:00
axi-symmetric mesh of dieselFoam az1362f OpenFOAM Running, Solving & CFD 2 June 27, 2009 11:32
DieselFoam does not restart from latestTime lord_kossity OpenFOAM Bugs 8 February 21, 2009 13:54
