Wmake error
Old   January 28, 2009, 23:07
Default Dear all I am trying to comp
Murasaki Shikibu
murasaki is on a distinguished road
Dear all
I am trying to compile a program using wmake. However when I compile I get the following long error message
c++/4.3.1/bits/postypes.h:50:35: error: stdint.h: No such file or directory
In file included from /home/steven/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../lib/gcc/i686-p c-linux-gnu/4.3.1/../../../../include/c++/4.3.1/bits/char_traits.h:48,
from /home/steven/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/../lib/gcc/i686-p c-linux-gnu/4.3.1/../../../../include/c++/4.3.1/string:47,
from /home/steven/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/string.H:51,
from /home/steven/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/word.H:44,
from /home/steven/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/int.H:40,
from /home/steven/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/label.H:55,
from /home/steven/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/labelList.H:36,
from /home/steven/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Pstream.H:45,
from /home/steven/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/OPstream.H:37,
from /home/steven/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/parRun.H:36,
from /home/steven/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/fvCFD.H:4,
from setvelocity.C:34:
Does anyone one have any idea what is wrong ? The programs run ok so does foam installation. I am using. I am using gcc 4.3.1 Is it because of this is too old version ?
regards
Murasaki
murasaki is offline   Reply With Quote
Old   January 29, 2009, 00:59
Default You are missing some basic dev
Martin Beaudoin
mbeaudoin will become famous soon enough
You are missing some basic development packages on your system.
The one providing the file stdint.h, among other things, is called libstdc++-devel.
On my OpenSUSE system, the complete name for this RPM is called libstdc++42-devel-4.2.1_20070724-17 .
Martin
mbeaudoin is offline   Reply With Quote
Old   February 10, 2009, 04:59
Default Where can I download this pack
Murasaki Shikibu
Where can I download this package ?
What other development pakages do I need ? Is there a list?
Murasaki
Old   February 10, 2009, 11:52
Default > Where can I download this pa
Martin Beaudoin
The person who did the installation of your workstation should have a pretty good idea...
Martin
Old   July 30, 2010, 04:34
Robyn
robyn is on a distinguished road
Let's say that person doesn't know where to get the package from for the installation where should that said person go? I also have the same problem but did the installation of OpenSUSE and am still knew to the programming world but have made my way through OpenFoam. Now I'm trying to implement a new solver such as simpleFoam with a heat gradient capability but have run into the problem listed above.
Would love to hear your thoughts!
Regards,
Robyn
robyn is offline   Reply With Quote
Old   July 30, 2010, 08:53
Retired Super Moderator
Bruno Santos
Greetings Robyn,
Got problems with OpenSUSE+OpenFOAM? Get them fixed here: http://www.cfd-online.com/Forums/ope...-2-11-3-a.html
In that thread, Alberto posted two links to his blog on How to install OpenFOAM 1.7 in OpenSUSE 11.2 and 11.3.
If that isn't enough, you'll have to be more specific with your questions
Best regards,
Bruno
Old   August 9, 2010, 14:03
Default Getting libraries
Bernhard Linseisen
Linse is on a distinguished road
Else, the first thing I would try is to use YAST or YUM (depending on the system used) and look for this libstdc-thingy.
To my experience, most often I did find the file just somewhere in the normal repositories. The "devel"-packages just often are not installed, because they are needed only seldom for the daily user.
For YUM, something like
"yum install *libstdc*" might already give you something you desire, for YAST I do not know the commands. Though at both you will need to be Root or at least specific rights...
Linse is offline   Reply With Quote
Wmake as User sven82 OpenFOAM Installation 3 August 14, 2013 03:23
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
Anyone using distcc with wmake kar OpenFOAM 2 March 14, 2008 05:13
Wmake error OpenSUSE 103 64 bit arch tom OpenFOAM Installation 5 February 8, 2008 12:57
Wmake error suffix or operands invalid for bpushb stefan82 OpenFOAM Installation 2 May 16, 2007 09:56
