February 13, 2010, 07:53 |
reference area
Andrea Pasquali
Rep Power: 16 |
Is there in OF a code to calculate the frontal area "Aref" (for example the car frontal area) to calculate Cx and Cz using "forceCoeffs" function? Thanks, Andrea
Andrea Pasquali |
February 14, 2010, 09:33 |
liftDrag
Andrea Pasquali
Rep Power: 16 |
I found "liftDrag" application for OF1.4. I try to compile it on my OF 1.6.x without success... Does any version exist for OF1.6 or 1.6.x ? Does this application calculate the frontal area "Aref" ? Thanks for any help! Andrea
Andrea Pasquali |
May 5, 2010, 10:41 |
Hi Andrea,
I am also looking for a way to easily calculate the frontal area of a complex 3D body. So far, it seems the only way to do it would be to sum the (area vectors dot the normal vector) on a whole physical surface and ignore negative values (to avoid having a zero total area!). The code involved would look something like Code:
mesh.Sf().boundaryField() and a loop like Code:
forAllConstIter(labelHashSet, patchSet_, iter) Best regards, -Louis |
May 17, 2010, 20:13 |
I have looked into it some more and here's the exact command that will give you the frontal area (in x-direction)...
Info << "***********" << ( sumMag(Sfb[patchi].component(vector::X))/2 ) << "***************" << endl; -Louis EDIT: that formula only works if the part has no concavity (ie: holes inside) because this would count areas that should not be counted... Last edited by louisgag; May 18, 2010 at 16:19. |
June 10, 2010, 02:20 |
Björn Bergqvist
Rep Power: 17 |
________________________________________ Björn Bergqvist, creator of Discretizer, a free mesh generator for OpenFOAM _________http://www.discretizer.org_____________
August 4, 2010, 16:55 |
thanks for this very useful link. Just a note, if your shape contains some concavities you need to select cells through (or actually skip the extract selection step) and then divide the final result by two.
Cheers, -Louis |
August 5, 2010, 04:31 |
reference area
NAVEEN.K.M
Rep Power: 17 |
hi louisgag,
Total area can be calculated using the liftdrag utility in OpenFOAM 1.4.1 by running liftDrag and put the same area at the end of controlDict of OpenFOAM 1.6.... Regards, Naveen |
August 5, 2010, 13:00 |
Thanks Naveen.
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 09:27 |
