-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Write out temp object during simulation (http://www.cfd-online.com/Forums/openfoam/78946-write-out-temp-object-during-simulation.html)
deji August 6, 2010 14:01
I would like to write out a temporary volScalarField object:
virtual tmp<volScalarField> alphaEff
during simulation. Is this possible to do in OpenFOAM somehow?
Best regards
Deji
l_r_mcglashan August 6, 2010 14:51
Why make it temporary if you want to write it out?
And I've never seen a virtual variable before.
However, I see what you're getting at. You can use .write() to write that object to file at any point in a simulation. Or you can create an IOobject with AUTO_WRITE, and assign alphaEff to it. Then it will be output every writeInterval (in controlDict).
olesen August 7, 2010 05:11
I think he's referring to the method itself, which is virtual and which returns a tmp<volScalarField>.
olesen August 7, 2010 05:19
No problem, just use the write() method but note that this method belongs to the underlying class and not to tmp<> itself.
Since the alphaEff method returns a tmp<volScalarField> you'll either need to dereference it, or create a volScalarField from it.
Option 1 (not particularly elegant), create a volScalarField:
  volScalarField alphaEff = turb.alphaEff();
  alphaEff.write();
Option 2, using a dereferenced tmp:
  tmp<volScalarField> talphaEff = turb.alphaEff();
  talphaEff().write();
Option 3 is the most succinct and also uses a dereferenced tmp but without an intermediate variable. This is what I'd use.
  turb.alphaEff()().write();
I hope this helps.
l_r_mcglashan August 7, 2010 07:23
Although you may not want to write out the file evey time step. Perhaps enclose it in this?
if(runTime.outputTime())
deji August 7, 2010 18:01
Thank you very much guys. I will try your suggestions in my computation.
Best regards
Deji
saba_saeb June 4, 2013 09:39
Anyone happen to know how I can output nuTilda field calculated in SpalartAllmaras model?
Cheers,
Saba
