Home > Forums > OpenFOAM
DNS two-phase flow
Old   August 10, 2010, 05:51
Default DNS two-phase flow
Claus Meister
idrama is on a distinguished road
Hello Foamers,
might anybody tell me how I can run two-phase DNS simualtion in OpenFOAM! What I have to do?
Cheers
idrama is offline   Reply With Quote
Old   August 11, 2010, 03:07
Suresh kumar Kannan
kumar is on a distinguished road
I think to run a DNS two phase flow you have to use interFoam as used in the dambreak case. But make sure of the schemes you select in the fvSchemes, they should be appropriate for a DNS simulation (second order).
kumar is offline   Reply With Quote
Old   August 11, 2010, 03:17
Claus Meister
Shall I apply every Gauss linear, make the mesh as small as possible and, moreover, turn LES or RANS off?
Old   August 11, 2010, 04:28
Suresh kumar Kannan
Hi
i think Gauss linear is ok but for making the mesh follow some criteria like the theory of univeral equilibrium by kolmogrov explained in Batchelor book and also in the paper
"Direct numerical simulation and analysis of instability enhancing parameters in liquid sheets at moderate Reynolds numbers" Physics of Fluids 20, 053301 (2008).
Also search on the forum for the settings, may be somebody has posted some information for the choice of the schemes. I cannot really tell you because I am working on LES of two phase flows. I have not really tried any DNS for two phase flows, but I am also looking into the possibilities.
regards
K.Suresh kumar
Thread Tools
Trackbacks are On
behavior of two phase flow in a pipe Sonia84 FLUENT 5 September 17, 2013 16:31
Two phase flow in a distributor Mohsin FLUENT 5 May 24, 2010 02:57
Two Phase flow modeling in commercial softwares Sandeep Rane Main CFD Forum 9 February 17, 2010 07:23
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
Two phase flow in porous media Madhavi Krishnan FLUENT 3 June 6, 2005 05:52
