NSRDS functions, liquid properties
Hallo Foamers,
the liquid properties of C10H22 are defined in the file .../src/thermophysicalModels/liquids/C10H22/C10H22.H The density is calculated with the NSRDS function 5 in .../src/thermophysicalModels/thermophyicalFUnctions/NSRDSfuntions/NSRDSfunc5/NSRDSfunc5.H Here it seems, that the density is only dependent on temperature, and not on pressure. Is the pressure dependency of density taken into account in OpenFoam? All answers welcome. Markus |
I worked on kerosene(C12H26). i had the similar doubt when i started the work.
In the present 1.7.x code, the density depends only on temperature. i don't think it is too difficult to make it function of both T & P. |
| All times are GMT -4. The time now is 06:31. |
