September 21, 2009, 13:10 |
calcMassFlow - problem in v1.6
Vojtech Betak
Rep Power: 18 |
Hi everyone,
I've compiled successfully on my PC ( IntelCore2, OpenSuse 11.1 x86-64 ) calcMassFlow function. But after restart my PC give me this function the following error message ( in the moment when it starts compute fluxes on faceZones ) Time = 100 Reading/calculating face flux field phi Flux at inlet = [1 0 -1 0 0 0 0] -0.033852 Flux at outlet = [1 0 -1 0 0 0 0] 0.0338555 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/vbetak/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/vbetak/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::FaceSetUtilities::checkFaceSetSides(Foam::fv Mesh const&, Foam::faceSet&) in "/home/vbetak/OpenFOAM/vbetak-1.6/lib/linux64GccDPOpt/libcellFaceSetUtilities.so" #4 main in "/home/vbetak/OpenFOAM/vbetak-1.6/applications/bin/linux64GccDPOpt/calcMassFlow" #5 __libc_start_main in "/lib64/libc.so.6" #6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 Unauthorized access to memory (SIGSEGV) Please can you give me an advice how can I repair this error. Thank you a lot. Vojta |
September 21, 2009, 15:59 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Bernhard |
September 22, 2009, 01:28 |
#3 | |
Vojtech Betak
Rep Power: 18 |
I've downloaded this version from http://openfoamwiki.net/index.php/Contrib_calcMassFlow Vojta |
September 22, 2009, 12:45 |
#4 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
August 20, 2010, 07:13 |
calcMassFlow for 1.6
Hi All,
I would like to know where I can download the utility to calculate mass flow rate calcMassFlow for version 1.6 Regards Raghu |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
convergence problem | Trushar | Phoenics | 5 | August 27, 2002 23:40 |
