what is nutilda?
Dear Foamers,
What is nutilda? i found it in 0 folder of les and kepsilon of pisoFoam tutorial (also other solvers). what should be its value in boundaries: wall, inlet, outlet ? Best, |
nuTilda is for the Spalart-Allmaras turbulence model (the value solved for that determines the turbulent vicosity). See: http://www.cfd-online.com/Wiki/Spalart-Allmaras_model
The nuTilda file will ignored unless you have enabled the SA turbulence model. |
do you mean it is not important when using k-e, LES & ... turbulence methods? it is available in o folder of these tutorials. also tell me about "nut" and "nusgs" if possible. Regards, Maysam |
nuSgs is the choice of wall function for the incompressible LES. Simply, kinematic viscosity.
Check it out? http://www.openfoam.org/docs/user/turbulence.php |
Hello everyone,
In continuation with the topic, how does one determine the values of kqRWallFunction and epsilonWallFunction? Thanks, Sagun |
