August 31, 2010, 06:15 |
Fluent mesh conversion to OF
Ovidiu Michiu
Rep Power: 15 |
I'm trying to convert a mesh from fluent to OF. The conversion is working perfectly, but it think i don't have all the files converted. OF creates all the files excepts "boundary" file. So, my question is: I have to define (write) myself the boundary file or this can be done in gambit or fluent? Best Regards, Ovidiu |
August 31, 2010, 06:43 |
Jean El-Hajal
Rep Power: 15 |
Dear Inginer,
you can define the boundary in Gambit. After conversion to OpenFoam check the constant/polyMesh/boundary file: usually the conversion from fluent to OF change the wall boundary to patch type, so will have to manually change them back to wall. Regards, Jean |
August 31, 2010, 08:06 |
Ovidiu Michiu
Rep Power: 15 |
Thk Jean,
I can see the mesh. The next step is to write the files from system directory and launch the application. Best Regards, Ovidiu |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ICEM] Using Surface Mesh from ANSA for Fluent Sim | tommymoose | ANSYS Meshing & Geometry | 15 | March 3, 2016 17:29 |
[Commercial meshers] Fluent Mesh (XP32) to OpenFoam | archymedes | OpenFOAM Meshing & Mesh Conversion | 1 | April 1, 2010 05:26 |
[Commercial meshers] Wrong face orientations after conversion from fluent mesh | stevecollie | OpenFOAM Meshing & Mesh Conversion | 6 | July 14, 2008 07:20 |
Import ICEM Mesh to Fluent | Fluent Beginner | FLUENT | 5 | June 23, 2004 00:27 |
