not outflow at outlet in interFoam
I've a simple square geometry with a irregular (up-and down) bottom. BC are inlet, outlet, top-atmosphere and walls in interFoam laminar. The model runs but not with my expected results. The problem is, that there's no outflow at the outlet. Looks like a closed wall, liquid (aplha1) is bouncing backwards. checkMesh is OK. My BC: p_rgh: inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } U: inlet { type fixedValue; value uniform (0.5 0 0); } outlet { type zeroGradient; } alpha1: inlet { type fixedValue; value uniform 1; } outlet { type inletOutlet; inletValue uniform 0; value uniform 0; } Thanks for help, Nico |
I would suggest you use zeroGradient for the outlet of alpha1. |
Thanks for your answer,
setting alpha1 on zeroGradient was my step before. The model runs only 1-2 seconds and this error message occurs: MULES: Solving for alpha1 #0 Foam::error::printStack(Foam::Ostream&) in "/home/trauth/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/trauth/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libOpenFOAM.so" #2 in "/lib64/libc.so.6" #3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/home/trauth/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libfiniteVolume.so" #4 void Foam::MULES::explicitSolve<Foam::geometricOneField , Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double) in "/home/trauth/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, double, double) in "/home/trauth/OpenFOAM/OpenFOAM-1.7.0/lib/linux64GccDPOpt/libfiniteVolume.so" #6 in "/home/trauth/OpenFOAM/OpenFOAM-1.7.0/applications/bin/linux64GccDPOpt/interFoam" #7 __libc_start_main in "/lib64/libc.so.6" #8 at /usr/src/packages/BUILD/glibc-2.11.2/csu/../sysdeps/x86_64/elf/start.S:116 Gleitkomma-Ausnahme Any idea what could be the reason? Thanks |
Hm, this is strange indeed.
It concerns the MULES solver for solving the VOF-equation. I would suggest you to re-check everything converning alpha1 including boundaries and initial condition. |
Can you post a little pic about the geometry?
Bye. |
1 Attachment(s)
Here's my geometry.
- Inlet on the left, outlet on the right side, both bc are only in the lower part of the sidewalls. - The top boundary is set as atmosphere. - Bottom, front, and backside are walls. The Mesh is coarse, maybe refinement would lead to better results?! Thanks for your help. Nico [IMG]file:///home/trauth/Dokumente/Graphics/geo.jpg[/IMG] |
How does your initialisation of alpha1 look like? |
0/alpha1, in this case OF crashes after 1.78 sec. right and left are the sidewalls above inlet and outlet. Code:
FoamFile Code:
FoamFile |
Hello Nico, first settings appear to be correct, except for:
A little shortcut to start with this problem is to put a wall on the top (atmosphere) and to use inletOutlet in the top part of the inlet to ensure air entrance. Regards. |
Hello Santiago,
Here my 0/U: I guess pressureInletOutletVelocity equates almost to inletOutlet. Code:
FoamFile Code:
FoamFile Do you mean the boundaray-file with initialization?: Code:
FoamFile Quote:
aplha1: inletOutlet into zeroGradient U: pressureInletOutletVelocity into type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); interFoam runs only 1.3 seconds. Quote:
Thanks for help. Regards, Nico |
Nico, your settings appear to be OK, I only would change (as you already did) the bouyantPressure BC by zeroGradient. Pressure equation is Poisson-like, therefore zeroGradient is the correct BC for walls. I would use these settings with a very small timestep, i.e. 1e-7, and then would increase it until run explodes.
Try this, if you continue having problems, please post the output. Good luck. |
I forgot to give aplha1 in setFields a value, I neglected it before (thanks to Sega;)). My geometry is now half filled with water at time 0. InterFoam runs. Quote:
I took the BC from the damBreak tutorial. I think at least here, correct BC should be used. Thanks, Nico |
no outflow in interFoam
dear FOAMERS,
I used type inletOutlet; inletValue uniform (0 0 0); for U at the outlet and type zeroGradient; for alpha1 at the outlet and tried aswell type inletOutlet; inletValue uniform 0; for alpha1, and all these settings work fine with OF 1.7.1 but create no outflow at OF 2.1.x., so maybe there is some change between the versions? |
using PISO instead of PIMPLE solved the problem
2 Attachment(s)
Ok turning old searching the cause of alpha1 being reflected at the outflow, I finally got it (ints not about PISO and PIMPLE). Maybe this is a bug dependent on ubuntu version, but it is quite relevant. The difference between the two pictures below showing an outflow of a channel is only that I moved the grid from positive x quadrant to negative x quadrant. When the whole grid lies at a position that the x-coordinates are smaller than 0 the outflow works! If using zeroGradient for p_rgh at the outflow, it works aswell fine for a grid with positive x coordinates. Anyway, I would be happy for any explanation on this.
Dear Albrecht,
Since this is more than 10 years from your post here and the problem still exists in the new versions of OpenFOAM, I'll prepare a bog report and submit it to the OpenFOAM. Best regrads |
